charging problem
Old Dec 31, 2009 | 09:22 AM
danielhardyone's Avatar
danielhardyone
6th Gear
Default charging problem
service charging system comes on every 2 min. new alt,batt,checked starter .gauge shows 14.2 most of time, when you first start engine have to hit the gas petal to2000 rpm. then its 14.2 14.5 car at idle is12.9 when first stared.
Old Dec 31, 2009 | 09:41 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
guy just wrote on gen it was starter. take a look. moved: see here: http://forums.corvetteforum.com/c6-t...lly-fixed.html
Old Dec 31, 2009 | 10:52 AM
SgtRod's Avatar
SgtRod
What spark plugs do you have? Ngk or non AC Delco?
Old Dec 31, 2009 | 11:37 AM
AndrewZPSU's Avatar
AndrewZPSU
What are your modifications if any? I'm mostly interested to see if you have a UDP.
Old Dec 31, 2009 | 01:02 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with this question!!!! Been there, done that and it was the cause of my issue.
Old Dec 31, 2009 | 02:53 PM
danielhardyone
6th Gear
autolite plugs
Old Dec 31, 2009 | 02:55 PM
danielhardyone
6th Gear
no mods in last year.
Old Dec 31, 2009 | 03:28 PM
The Clevite Kid's Avatar
The Clevite Kid
St. Jude 15 Year Donor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Spark plugs make a difference, us AC-Delco Iridium
See page three of THIS THREAD for more information on plugs, alternator wire routing, and the "Service Charging System" message.
Old Dec 31, 2009 | 03:48 PM
silver93vert's Avatar
silver93vert
I had the same problem....ended up being the spark plugs. I put in Ngk tr6's when I put on the Trickflow heads....using anti-sieze on the threads. Replaced the plugs with new tr6's and no anti-sieze = no more issues. One possibilty for ya.
Old Feb 13, 2010 | 06:47 AM
milkybar2010's Avatar
milkybar2010
3rd Gear
I also have this problem. Fortunately I purchased an extended service plan. To see the life of your battery, open CMD prompt as administrator and type in "powercfg -energy -output c:\energy-report.html" and when the report is finished, open your browser and type in the address given... for me it was c:energy-report.html
My battery currently holds about 37% capacity @ 'FULL' charge, and this is just over a year after buying it.
Self Certified Buy To Let Mortgage
Small Business Loan Calculator
Old Feb 13, 2010 | 03:16 PM
HC Mechanic's Avatar
HC Mechanic
Yep, anti-seize is old school.
May be necessary for iron heads...but not aluminum. Can also allow you to strip out the threads in your nice alum. heads. That would be a sad day in Mayberry
Old Feb 14, 2010 | 03:48 AM
HuskerBullet's Avatar
HuskerBullet
Wait a minute, I'm not sure what your complaint is?? Although you say you have a new battery and alternator, I'm a EE and even though I may not have the answer, I really don't know what your problem is....can you be more detailed as to what is abnormal?
To charging problem
