LS2 Cam question. Piston clearance?
Old Jan 2, 2010 | 12:12 AM
Adam Sean's Avatar
Adam Sean
Default LS2 Cam question. Piston clearance?
How big can a cam be on a stock long block LS2 before piston to valve clearance becomes an issue?
Old Jan 2, 2010 | 09:53 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Usually LS2's w CATHEDRAL HEADS have no problems with cams with lifts
of 600 and durations of 230's. The geometrics permit that. On the other hand it is a major factor on LS3's or ls2 w l92 HEADS. There are plenty of posts here on the forum and SPINMONSTER has a nice write up on the subject .
Old Jan 2, 2010 | 01:11 PM
Louis @ LG Motorsports's Avatar
0Louis @ LG Motorsports
Former Vendor
It all depends on where the cam is. a 230 cam with lots of advance will have less PTV than a 240 cam with ICL retarded....
Old Jan 2, 2010 | 03:42 PM
HC Mechanic's Avatar
HC Mechanic
How much is considered lots of advance?
Old Jan 3, 2010 | 09:26 AM
BartonekDragRacing's Avatar
BartonekDragRacing
i'm running a 235/240 .647/.604 lift cam (Texas Speed Tsunami) on my stock headed LS2 with no clearance issues.
Old Jan 3, 2010 | 12:30 PM
z2898's Avatar
z2898
2016 C6 of Year Finalisof Year Finalist
how about a G6X3 with maybe .040 head gaskets instead of stock head gasket to bump up cr a bit for that cam. with Ls2 heads. im just checking cause was thinking of goin that route. does anybody know what the cr would be if doing that?
Old Jan 3, 2010 | 01:34 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I have the G5x3 with .040's and no fly cutting. As I recall 11.4:1 SCR and 8.4 DCR. Dyno and track results in sig. The car is my daily driver.
Your SCR would be the same, though DCR would be different. I'd fathom a guess that DCR would be higher as the cam is on a 111 ICL IIRC. Mine is a 114 ICL.
Here is an excellent post on calculating SCR and DCR that my friend put together.
http://forums.corvetteforum.com/c6-t...tio-chart.html
Old Jan 3, 2010 | 01:50 PM
Former Vendor
If you are running any big cam with L92s, you will need to mill them. when you mill them, you decrease PTV. With this, you need to flycut.
The G6x3 is a large/r cam, and PTV will be close, but not out of this world.
When I say advance, Im talking no more than 5*. Retard 2-4*
Keep in mind, that every Degree ICL changes, it changes PTV ~.004 depending on the lobe. I have seen as little as 3.5 thou/degree up to 6 thou per degree.
Louis
To LS2 Cam question. Piston clearance?
