Rear End Recommendations??
Old Jan 6, 2010 | 09:51 AM
Hogvette's Avatar
Hogvette
Default Rear End Recommendations??
New rear-end is my next mod with Chuck Cow package... I see several options from 3.42, 3.73, 3.90 - even 4.10! How much is too much? Any recommendations on which setup?
I currently have stock 2.56 on my 2007 A6. I'm not heading to the track - just want that boost when I ask for it on street driving. Thanks for any constructive input you can offer.
Old Jan 6, 2010 | 10:46 AM
Silver Bullet C6's Avatar
Silver Bullet C6
St. Jude Donor '10-'11-'12
The A6 and M6 gear ratios are different. For A6 most people start out with a 2.56 and most upgrasde to a 3.15 or a 3.42 gear. I just talked to Quality Motorsports here in Dallas and they are about to install 3.73 gears on an LS3 with nitrous. I am looking to go 3.42 soon (hopefully this month). Quite a few here have 3.15 or 3.42 on their A6 trannies...perhaps they'll share their thoughts.
Old Jan 6, 2010 | 12:29 PM
TMRoc's Avatar
TMRoc
How long have you had your SC and WHP 580, I'm just wondering how the A6 is holding up ?
Old Jan 6, 2010 | 03:19 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
With absolutely no other mods or changes to your setup adding 3.42 gears will make the car feel like it has a 100 extra rwhp.
Old Jan 6, 2010 | 05:41 PM
Silver Bullet C6
I've been enjoying it since April '09. It has been the funnest mod so far. The improvement in HP leaves NO doubt you've put on a supercharger. My car is like my personal ammusement park now.
Old Jan 6, 2010 | 05:47 PM
Silver Bullet C6
That's what I'm talking about . I'm just needing to schedule my date/time with Quality Motorsports for 3.42 gears from RPM.
I forgot on the earlier post....the A6 trans is doing fine. When I talked to RPM they said the primary concern with the A6 and high HP is making sure you get the trans tuned right and keeping trans temp down.
My attitude is, "if I blow the trans, I'll just have RPM rebuild me another." Life is too short, I'm going to enjoy it & my car while I can.
Old Jan 6, 2010 | 07:14 PM
EuroRod's Avatar
EuroRod
If you chose the 3:42's, I'd suggest supplimenting the stock tranny cooler with a second unit positioned in the air stream. Heat is the killer of automatics.
Old Jan 6, 2010 | 09:04 PM
jpee's Avatar
jpee
I agree with you it "WILL FEEL" but will it perform like a car with an extra 100hp, I'm betting not..
Have him make a few 1/4 mile runs see what his ET & MPH are with the stock gearing, then after he changes gears..
I have found on more than one occasion that
Horsepower = MPH
Chassis Set Up = ET
.. in other words if he is NOT making more HP he is NOT going to pick up MPH.. yes gears will give him better ET..
And I have always said ET Wins Races Every Time, Not MPH!!
So yes the gears will get him a better ET (i.e Winning races) but his mph will stay within 1 or 2 from his original MPH..
Old Jan 6, 2010 | 10:43 PM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
Default Regardless of what anyone else thinks or says...
REGARDLESS OF WHAT ANYONE ELSE THINKS OR SAYS...PROPER GEAR SELECTION will ALWAYS make your car FASTER! and more fun.
That's not to say that the bigger the gear the faster your car will be...
If the gear is properly matched to the motor's power curve with adequate traction....IT WILL BE FASTER.
It won't just "feel" faster....It WILL BE FASTER.
For most A6 vehicles...I'll take the thinking out of it for you.
3.42 A6 ATTACK PACKAGE!
You follow?
chuck CoW
Old Jan 8, 2010 | 03:31 PM
dads toy's Avatar
dads toy
Sorry to hijack this thread. Chuck, I had an M6 in a 2001 TA making 508 hp and went from stock 3.42's to a Moser with 4.56's.
how does going from 2.56's to 3.42's in my 2007 A6 compare to an M6 gear change?
Hope this makes sense. I only know that the gearing is different in an M6 vs an A6.
Old Jan 9, 2010 | 05:39 AM
ScottJ03's Avatar
ScottJ03
Default 3.15 here
I lke my 3.15 because its gets out the hole quick.
With tire spin but not excessive. I think i am at 2500 rpm @ 70 mph.
I don't know what 3.42 will be at?
Either way you will get a kick in the a$$.
Old Jan 9, 2010 | 07:10 AM
Larry R. Quinn's Avatar
Larry R. Quinn
I love my 3.15's , but I'm running a little more horsepower than you . I am sure you would like either the 3.15 or 3.42 differential on a stock C6 . What Chuck says about " proper gear selection " is true . One should match their torque power curve to the gear . It is also nice to " tune " the new differential and decrease the shift time and clamping pressure . If you decide to tune your car , remove " torque management " so your car doesn't pull timing when shifting under full throttle . I will not make any claim that your car will be faster , but it will be even more fun to drive day to day . Enjoy !
Edit : I see that you already have a tune by Chuck , so I am sure that he has removed the torque management that causes many cars to " bog down " when shifting .
Old Jan 9, 2010 | 10:34 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default Not much difference.....except....
Not much difference.....except....That combination was likely a built motor which made more power upstairs...
To perfectly match the power curve of a stock motor, it seems that the 3.42 is the best choice A) because there really isn't another ratio available without going to the extreme and 3.15s are great, but leave a lot on the table.... B) having 3.42s is almost "unnoticable" to the driver on the highway and around town....
You actually have to watch the tach to know there is a gear in the car.
I've taken many customers for rides in 3.42 cars and they never knew it had a gear....until the LAUNCH!
We've done all the hard work for you! All you have to do is write the check!
Chuck CoW
Old Jan 12, 2010 | 10:14 AM
Elite275's Avatar
Elite275
Would a 3.73 then be recommended for an A4 if the 3.42 is the gear of choice for the A6?
Old Sep 26, 2011 | 04:57 PM
tlm2010gsc's Avatar
tlm2010gsc
Chuck, I have a 2010 GS A6 and am planning to upgrade to the edlerbrock 1591 SC package but wanted to do the rear end 1st and retune the trans. It looks like a 3.42 does the all all round trick for a DD and cruise mode. Really not into tracking it- YET !!!!
I know I need to retune the Trans but do I need an added cooler for it as well. That front end is going to get pretty crowded with all the mods. Do I need to send in the PCM to retune or is it downloadable????? Do I need to do it twice as well, once for the rear end, trans tune and then for the S/C?
Old Oct 10, 2011 | 11:38 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Default My advice would be.....
My advice would be to use 3.90s for an A4....
We have found 3.90s to be the best choice for C5 and C6 cars with A4 transmissions.
The difference between 3.73 and 3.90 is negligible and I believe the 3.90
is the better choice....
I have done MANY of them for Both C5's and C6s and I can mail order you a
perfect tune....
Especially when you buy the differential from US!
Stay TUNED!
Chuck CoW
Old Oct 10, 2011 | 11:43 AM
Chuck CoW's Avatar
0Chuck CoW
Former Vendor
Well, going from 3.42 to 4.56 is likely the same as going from 2.56 to 4.30 or 4.56
I would imagine....
The only thing to remember is that the A6 has an awesome FIRST GEAR and
two(2) really nice overdrives.
While the swaps DO compare as far as gains, please don't let that lead you to
believe that you're running around with the equivalent of 4.56s....
3.42s in an A6 car are AMAZING and the cars still get good mileage and
can cruise across the country with the best of them!
I wouldn't use any other ratio than 3.42 for an A6 car.
I LOVE REARS!
Chuck CoW
To Rear End Recommendations??
