Runflat tire replacement question -
1) My OEM Goodyear front tires need replacing, but the rears probably have another 8-9,000 left in them. Is there any reason I can't put either Firestones or Michelins on the front, and leave my Goodyears on the rear?
2) I drive my C6 year-round here in the northeast. I don't, of course, drive it in snow, but there are plenty of days I'm driving around in 20° temperatures. I like everything I've read about the Firestone Wideoval Runflats, except when I read the details online, they indicate "The Firehawk Wide Oval RFT is not intended to be driven in near-freezing temperatures, through snow or on ice". Can I really not use these to drive around in the winter?
Thanks . . . Stu
I changed my OEMs to Firestones about a year and a half ago, and have had no problems here in Chicago driving at very low temps, i.e., in the teens. That being said, you don't want to get on the accelerator hard and behave yourself around turns. For normal driving, however, I have had no problems.
yes, these tire's do say "summer time only" but if you careful you can make them work, but even most hi-perf tire's are for the warmer temps only, if your thinking about non-RF's I am running GY supercars non-RF all season on the front of mine, and yes it's hard for me to say what their like in really cold wheather, here it forty degree's for about five mins in the mourning. hey, Wingrider I went to HS in Downers Grove
How much tread do you actually have on your rear tires? They may be closer to replacing than you think.
Bill
CAUTION:
Mixing tires could cause you to lose control
while driving. If you mix tires of different sizes
(other than those originally installed on your
vehicle), brands, or types (radial and bias-belted
tires), the vehicle may not handle properly,
and you could have a crash. Using tires of
different sizes (other than those originally
installed on your vehicle), brands or types, may
also cause damage to your vehicle. Be sure to
use the correct size, brand, and type tires on all
four wheels.
________________________________________
Sometimes you can "break the rules" and be OK. Just be careful. One time I drove 60 mph in a 55 mph zone, and I lived to tell about it.
Anyway the car handles just fine with the mixed tires.
Also, different tires that perform similarly in the dry can behave very differently in the wet, so be conscious of that. Ditto with extreme cold.
There are no doubt combos that happen to work, but the car was set up assuming front and rear contact patches with the same traction properties, which is most reliably accomplished by changing all four.
