Performance tires vs Runflats
Old Jan 7, 2010 | 07:57 AM
luckycharm's Avatar
luckycharm
1st Gear
Default Performance tires vs Runflats
Hello, I need new tires and trying to decide if I should get runflats again or if I should get regular tires. I figured if I get normal tires and get a flat I will either 1. plug it or 2. call a tow truck but atleast get the full feel of a performance car and of course its cheaper than runflats. What are ya'lls thought's and does anyone have regular tires that they would recommend for all seasons. Thanks
Old Jan 7, 2010 | 11:30 AM
CMY SIX's Avatar
CMY SIX
went to regular tire's and will never go back to runflats!!! I love the Idea of RF's, but the difference is night and day!
Old Jan 7, 2010 | 12:00 PM
TrenAman's Avatar
TrenAman
unless you get flat tires all the time then without question get some good rubber..
Old Jan 7, 2010 | 12:16 PM
Walt White Coupe's Avatar
Walt White Coupe
Go performance and carry a cheap, small compressor. That will take care of most tire pressure issues to get home or to a repair facility.
Old Jan 7, 2010 | 02:42 PM
torquetube's Avatar
torquetube
Default Horses for courses
"Run-flats" aren't a monolithic thing. For that matter, "performance tire" is a meaningless term as well.
Which "run-flats?" Supercars? G2s? GS-D3s? Wide Ovals? PS2 ZPs? Something else? They're not all the same.
Which "performance tires?" DOT R-Compound will embarrass anything on hot dry pavement, but get a little damp and you're in the weeds - meanwhile the guy on G2s is pulling away. So much for "performance."
The C6 is a street car, and certain run-flats (I like the PS2 ZP) are awesome on the street. Excellent grip and very handy for flying around the back-roads way out in the narrow twisty boonies, where there's no cell coverage, and a blowout would really ruin your day.
Old Jan 7, 2010 | 04:44 PM
Vito.A's Avatar
Vito.A
I also switched from the OEM Goodyear Extended Mobility tires to the Michelin PS2 with conventional sidewalls.
If the goodyears were free, I would not spend the money to mount and balance them. The difference is dramatic.
I carry a small Craftsman 12V air compressor and a quality plug lit in the left rear compartment.
Old Jan 7, 2010 | 06:59 PM
VetteFlyer09's Avatar
VetteFlyer09
I agree with switching to non-runflats. The price difference more than covers a tow or the purchase of an aircompressor and tire repair kit. Plus the TPMS gives added security. With a quality replacement tire maintained at proper pressure, a catastrophic failure is rare. A slow leak caused by road debris would be detectable by TPMS. I know the Shelby GT500 does not use runflats and has no spare, and considering Fords past tire issues....... The next issue is which tire to mount, with your all-season requirement. This could be a whole other discussion, but for bang for the buck..... I have had good experiences with Nitto NT555 and Sumitomo in the wet weather.
Old Jan 7, 2010 | 09:17 PM
luckycharmer03's Avatar
luckycharmer03
Thank you everyone for the advice. I have decided to definitely go with regular tires.
Old Jan 7, 2010 | 09:35 PM
luckycharmer03
So I am looking at Michelin Pilot Sport PS2 in comparsion to Nitto 555 Extreme Performance tires. It looks like Nittos rate better than Ps2 ...is there a reason Nitto is alot cheaper? What am I missing here?
Old Jan 7, 2010 | 09:52 PM
luckycharmer03
excuse what may be a silly question but will my size 245/40-18 and 285/35-19 size change when I switch from run flats to regular conventional tires. want to make sure i order correctly.
Old Jan 7, 2010 | 10:46 PM
rws.1's Avatar
rws.1
runflats = assurance
performanace tires= well performance...
Only you can decide why you bought the Vette.
Old Jan 7, 2010 | 10:55 PM
Hogvette's Avatar
Hogvette
PS2 ZPs are huge improvement over stock GY!
Old Jan 7, 2010 | 11:06 PM
Atomic 08's Avatar
Atomic 08
8th Gear
I've read a lot of bad reviews on the Nitto Invo's about them being too soft on the corner. So what is the best tire for ride and wear for the buck?
Old Jan 8, 2010 | 09:28 AM
rag1998's Avatar
rag1998
I am looking for a set myself..please suggest which would be the best Nitto's or PS2 ZP
Old Jan 8, 2010 | 10:47 AM
Wass's Avatar
Wass
St. Jude Donor '09-'11
You can order non-RF "conventional" tires in your stock tire sizes.
A lot of forum members like the Nitto Invo tires much more than stock tires, myself included. When you consider what you are getting for the price, they are a pretty good deal.
Old Jan 8, 2010 | 03:55 PM
PeterM's Avatar
PeterM
I also found the Invos to be much nicer than the stock runflats.
I also carry the Slime kit that includes the performance compressor.
Old Jan 8, 2010 | 03:59 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
^^^^^^^ Agreed ^^^^^^
I paid less than $900 for my set of Nitto Invo's and can't believe the quality, ride and wet/dry performance these tires have. If and when I wear them out I will buy them again!
To Performance tires vs Runflats
Old Jan 8, 2010 | 04:46 PM
rag1998's Avatar
rag1998
Which Nitto's are you all running...model nos??
Old Jan 8, 2010 | 07:41 PM
jstewart's Avatar
jstewart
Default tire choices
I am also on the cusp of needing new tires. The Goodyears on my 08
Z-51 C6 have 9500 miles. They are not worn out yet but traction in cold weather on dry roads is iffy. I added headers, a CAI and a dyno tune just before it got cold and 1st gear traction disappeared. I am now in the process of installing Spins cam package, adding compression and doing a ported intake & TB. I have to find better tires. Will either the PS2's or the Nittos provide significantly more grip in warm weather than the Goodyears in stock sizes??? I think cold weather traction is a lost cause with this setup.
Old Jan 8, 2010 | 08:56 PM
goatts's Avatar
goatts
Kumho. The guy at Tirerack said most vette owners go with non runflats. Kumho had the best grip in a recent magazine test and they were cheapest.
