MY BUILD PLANS (tenative)
Old Jan 7, 2010 | 09:44 PM
cell6ida's Avatar
cell6ida
Default MY BUILD PLANS (tenative)
different build
Old Jan 8, 2010 | 12:21 AM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
There is no way to estimate the power without knowing the cam specs. The cam will vary the power greatly. Sounds like a stout combination you are putting together.
Old Jan 8, 2010 | 07:38 PM
cell6ida's Avatar
cell6ida
Any other comments on this build?
Old Jan 8, 2010 | 08:00 PM
AndrewZPSU's Avatar
AndrewZPSU
With the right cam you can hit close to 500 rwhp (on an M6) with that setup.
If you go with a baby cam you'll be seeing around 460 rwhp pretty easily.
Old Jan 8, 2010 | 08:31 PM
TrenAman's Avatar
TrenAman
save $ and do not port the heads.. only 10-15rwhp max gains on it.. scratch the fast intake also.. just port the stock LS3 intake and you will be close to the fast for many hundreds cheaper..
If I had to start all over.. I would go with a procharger F1 or a TVS 2300.. Easily taken off if you ever want to sell it.. and will make a ton more power than what you have listed above..
To MY BUILD PLANS (tenative)
