How to spend 4K?
Old Jan 8, 2010 | 12:54 PM
EATURAW's Avatar
EATURAW
Default How to spend 4K?
Here is where I'm hung up - I'm a new Vette owner and have been doing a ton of research here on the forums.
I need to figure out what route to go... I have a 2008 C6 Z51 M6, a Procharger sounds fun. From what I have been reading you're looking at an instant 150rwhp just bolting it on - with no exhaust or anything. I think average price for that is about $5,600, not including install.
I'm looking for opinions from people who have had it done, how much total did it run you - all said and done.
Then I could go the bolt-on route, intake, headers, X-pipe, tune and maybe a cam.. All said and done aren't I looking at a close price to the Procharger? Are bolt-ons really worth it?
I'm stumped guys, any input?
Old Jan 8, 2010 | 01:09 PM
zzzzzzzzzzomg's Avatar
zzzzzzzzzzomg
5th Gear
Procharger is going to be a lot more than $5600. It's not just the head unit and some piping to get it working, you need fuel supporting mods etc. In the end it will be close to $8000 installed.
You can get intake/exahust/cam installed for 2-3000 and pick up quite a bit of power. Not as much as procharger, but costs almost a third less.
For $4000 I would do LT, xpipe, intake, cam and if you have any money left use that to port the intake manifold and the heads.
Old Jan 8, 2010 | 01:41 PM
TrenAman's Avatar
TrenAman
hey bro, you on the af board? look familiar.. anyhow I picked up a used procharger kit here for $2500.. $150 later "injectors, BAP, install" I had a great setup.. There is usually a kit for sale every 2 weeks in the parts for sale section.. without a doubt the best bang for the buck! I did this after I bought damn near every bolt on out there for my LS3. Just running 3.5-4lbs of boost and close to 600rwhp.. going wide booty soon and will bump it to 12lbs!
ZZZZZZ said to port the heads.. he obviously does not know anything about a LS3.. just saying!
GET A SUPERCHARGER!!
Tren A Man
Old Jan 8, 2010 | 04:02 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Give us a call if you have questions.. I bet I can figure out a way to help you spend 4K wisely
__________________
Home of the Fastest Supercharged C5 8.4 @ 158mph
Home of the Fastest Supercharged IRS GTO 9.0@ 155
Home of the Fastest Supercharged C6 9.7 @ 143mph
Proud Sponsor of the ECS Corvette Challenge
http://www.corvettechallenge.info
609-752-0321
Old Jan 8, 2010 | 06:18 PM
wooden's Avatar
wooden
give chris a call,
Old Jan 8, 2010 | 06:39 PM
NYC6's Avatar
NYC6
A couple different Forum vendors are installing a Vortech S/C with ram air intercooler and all the associated bells and whistles, tune and before and after dynos for $6400 or so.Got mine last year. IMO, the best bang for the buck out there!
Old Jan 8, 2010 | 06:59 PM
GREENTAHOE's Avatar
GREENTAHOE
Drive a nice N/A set up and then a supercharged setup. See what you like. I've had superchargers, turbo's, and N/A. I like N/A best and will be doing a full N/A build on my LS2. You have an LS3 which means your starting up bit further up the ladder. Its a lot of money. You owe it to yourself to try before you buy. Peak HP numbers don't mean crap with regards to the driving experience.
Old Jan 8, 2010 | 07:05 PM
GREENTAHOE's Avatar
GREENTAHOE
BTW if that is you in your avatar you look great. I'll be requalifying for Nationals this year at the top of the Heavy's. Qualified and competed last time as a light heavy. Took 2 years and have definately stepped it up.
Old Jan 8, 2010 | 07:30 PM
Boomer111's Avatar
Boomer111
Understand you final goal first. Mods work together for greater improvement. S/C is the easiest and most power for the $ and can be emissions complaint.. Problems may arise compared to the N/A bolt on route, although here your emission laws come into play. Most will go N/A with headers, Intake, Muffler change for sound then followed by maybe gears and or cam. Porting follows too. Brakes wheels body kits not to speak of interior upgrades.
If you want bragging rights and serious speed go S/C. Otherwise $4,000 can get you maybe 40 to 50 rwhp with tune too.
I am just now installing 4.10 gears. All bolt on up to this point. Gears I hear gives the best sop performance for the $$. I will see shortly.
Old Jan 8, 2010 | 07:46 PM
TrenAman's Avatar
TrenAman
what boards you on? Bro is a conditioning FREAK from his avatar..
Tren A Man
Old Jan 8, 2010 | 07:55 PM
AndrewZPSU's Avatar
AndrewZPSU
I just responded on my thread with a pretty detailed way to spend it. If you want to see my car I'll be in Harrisburg, PA tomorrow doing a cam and heads install and would be more than willing to take you for a ride.
Old Jan 8, 2010 | 08:39 PM
66yellowstingray's Avatar
66yellowstingray
I would say save your money and move out of Pasadena.
Old Jan 9, 2010 | 01:40 AM
IROC-ZR1's Avatar
IROC-ZR1
4th Gear
i dont know much about vettes but i say it would be much better to go bolt ons like weight reductions, better tires, suspension mods, catback exhuast, headers, cam, porting, tune and whatever holds back the power from these cars for cheap. and then when you do some bolt ons in the future if you have the money buy the S/C and you would get much more power out of it plus with bolt ons it wont break the bank if you want a good about of power. again im use to thirdgen camaros but i think what i mentioned above pretty much supports any vehicle. good luck.
Old Jan 9, 2010 | 07:46 AM
Finster07's Avatar
Finster07
Well said. Exactly what I did, I tried both. After you try both, you can decide which is best for YOUR driving style and goals.
http://forums.corvetteforum.com/c6-t...s-n-a-ls2.html
Several posts here clearly speak to the pros and cons of each setup, S/C or H/C. Much of this thread discusses 1/4 mile times and trap speeds, which is not my goal, but there is excellent insight here as to what each setup brings to the table.
Old Jan 9, 2010 | 10:34 AM
goatts's Avatar
goatts
You may need to budget a little more than $4k either way you go but with NA you can do it one step at a time.
1. Vararam
2. Exhaust
3. Headers,tune
4. Cam
Old Jan 9, 2010 | 11:22 AM
Finster07's Avatar
Finster07
1. Vararam
2. Exhaust
3. Headers,tune
4. Cam
I was thinking the same thing. 4k won't get you a s/c, install, and tune. Not even close. But you can easily do any combination of the above. Add to the list a set of gears as a real SOTP addition. I love my 3.90's which cost about 2K.
Old Jan 9, 2010 | 06:22 PM
GREENTAHOE's Avatar
GREENTAHOE
Tren A Man
Now I get the user name!! I stay on MuscleChemistry. Very straight forward, knowledgable, mature guys. If it weren't for my real passion, I'd be driving a 9 second vette!!
To the OP, 4K will be plenty to wake that thing up. Cam, Headers, and tune and you'll be in one very quick vette!!
To How to spend 4K?
Old Jan 10, 2010 | 10:00 AM
C6BIX's Avatar
C6BIX
Default Funny
I was in the same boat last week.. I have 7K to spend on the car.. I was thinking all the same things.. Then i realized that if i do a cam it will void the motor warranty. I know its not that big of a deal but i really dont want to do that.. So I was like ok i will do headers and xpipe and Tune.. That was like 2500 .. for what 25HP.. This car is allready sickfast do i really need the 25HP??? I just got my car back in Austin Tx from Custom SOunds... I have a 7140 DD Nav DVD head unit put in and JL TW5 Sub and JL HD900/5 amp and componets put in.. I have to say that was a great choice.. I will listen and enjoy the system and love showing off the work more that 25HP. ALso I have anough to get a nice set of wheels and tires for C6 Z51.. I know you guys might flame me but i just wanted to give my 2 cents.
Old Jan 10, 2010 | 01:22 PM
EATURAW's Avatar
EATURAW
Thanks for all the input guys..
To TrenAMan - No, not a member of any boards. I'm a National level competitor w/ 5 state titles. I've done 9 shows in all including one national contest (IFBB GNC North Americans).
Very hard to make up my mind, I have read a lot of stuff about people throwing codes - even having surging with as little as a CAI and Headers. Been there done that with FI, I had an 06 Nissan 350Z. 400rwhp and 390rwtq on a stang dyno. It was nothing but head aches. Maybe I should just get a set of nice rims and tires.. I don't know, I'm going crazy trying to decide. I really don't feel like looking at another check engine light, that is beyond annoying.
Old Jan 10, 2010 | 01:41 PM
jmudreamvette's Avatar
jmudreamvette
You seem to have the modding bug like me, SO There are enough quality shops up there to go for some rides in both SC/ HC cars. Take you time, My last car I had was a 57 chevy with 700 HP alky motor with a full moly frame, NHRA cert. I wanted something I could drive, Sold the car for a vette. Great decision for me...
