LS2 Trick Flow Heads/Cam/Rockers kit
I was curious if anyone was running this package on their car? Any before and after rear wheel dyno numbers? Any opinions on quality / fitment? Thanks!
http://www.trickflow.com/egnsearch.a...=KeywordSearch
St. Jude Donor '09
http://forums.corvetteforum.com/c6-t...w-550-kit.html
San
Go with a proven set of parts for your car. I can give you factual part specs to get to 480 conservatively and 500rwhp without the use of a big split cam that wasnt developed for a corvette. The heads are 2400 and the rockers needed are about 450. The cam is 420 shipped from Comp Cams. All you need is gaskets, timing chain, and head bolts.
That kit was targeted at the heavier GTO and that price range buyer.
No one got to 550 flywheel with that package, nor can you expect the same results using the various other mods a corvette can have on it such as header brands and intake manifolds.
The heads arent specified as 215's or 225's nor is any flow data to show what level head you are getting. Stock gaskets and bolts along with generic cam specs make for serious questions of performance goals.
EDIT: cam specs are: 238/242 .595/.595. I dont know the LSA but I doubt this is a cam to live with for a daily driver unless the Lord tunes it.
A TF225 with a 234 cam hits 510-520rwhp.
I just got the trick flow top end kit heads 225s cam 238/242/595/595/112 long tube headers underdrive pulleys fast102 intake and t/b 4000 stall with 3:42 gears and 125 shot nos with 17" drag slicks just wondering about what the 1/4 mile et would be. Any guesses.
