LS2 Timing Marks
Old Jan 14, 2010 | 05:33 PM
cranky's Avatar
cranky
Default LS2 Timing Marks
installing new cam in 2005 LS2. not sure of the timing marks. could use some opinions from those who have done a cam install. thanks. cranky
Old Jan 14, 2010 | 06:43 PM
SDPC's Avatar
0SDPC
Former Vendor
Stock timing set? dot to dot. Crank dot straight up, cam dot straight down.
Old Jan 14, 2010 | 06:49 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
just did mine. if you have any questions during the install let me know.
read this...
http://www.ls1howto.com/index.php?article=23
Old Jan 14, 2010 | 07:49 PM
cranky's Avatar
cranky
read this...
THANKS !!!!
Old Jan 2, 2013 | 10:04 PM
NotStock's Avatar
NotStock
Default Compression or exhaust stroke
Know this is an old thread but I'm doing a cam install myself and had the same question. Before removing the original cam the only way I could get the crank timing mark in the 12 o'clock position and the cam timing mark in the 6 o'clock position with the number 1 cylinder TDC was on the exhaust stroke. Everything I've read about TDC says it should be on the compression stroke. When I do that, both timing marks are at the 12 o'clock position. Seems like if I install the new cam with its timing mark in the 6 o'clock postion it would be 180 degrees off. Really don't want to mess this up.
Old Jan 2, 2013 | 10:59 PM
vettefan12's Avatar
vettefan12
Its super easy. everyone always says make sure its on the compression stroke.... its simple 6 and 12 o'clock. dont make it any harder than it sounds. should take no more than 10-15 minutes to time it. get the marks lined up before you pull the cam gear and slip it back on with the marks re-aligned. simple
Old Jan 3, 2013 | 01:17 AM
debo's Avatar
debo
read this...
WOW! That's a good write up. Thanks for sharing.....
To LS2 Timing Marks
