Front Window Replacement
Old Jan 16, 2010 | 12:30 PM
430Vett's Avatar
430Vett
Default Front Window Replacement
I need to replace my front windshield and would like input in to glass quality and if there is a difference in the glass if you have a HUD.
Is the car sensitive to twisting when the window is out?
Any input would be helpful
Chris
Old Jan 16, 2010 | 05:16 PM
glennhl's Avatar
glennhl
Yes, the HUD requires a "HUD" Windshield. Ask for an OEM windshield for the HUD. Also, the windshield does not stiffen the car, it's NOT load bearing. Think about it, if it carried a load it would break.
Old Jan 17, 2010 | 01:01 PM
430Vett's Avatar
430Vett
Thank you for your input
Old Jan 17, 2010 | 04:12 PM
corvettenvy's Avatar
corvettenvy
As glennhl stated, there is a special windshield for HUD equipped vehicles. However, many owners have added HUD and not replaced the windshield. Although some have stated the visibility of the display is somewhat decreased, many seem perfectly satisfied with the quality of the display. I understand the difference in price is quite substantial so you will have to decide if it is worth the increased cost. Search for posts in C6 General for comments on this subject.
Old Jan 19, 2010 | 01:45 AM
mikeci's Avatar
mikeci
I had to replace my windshield last year. the man who replaced it said there is only one source for the glass and that's GM if you have a HUD
Old Jan 19, 2010 | 08:10 AM
Raphael Nirav's Avatar
Raphael Nirav
2nd Gear
Well check your local slavage yard they might have one or you will have to get one from a body shop or the body shop might be able to point you in a direction..miami limousine
Old Jan 19, 2010 | 11:14 PM
MADinAK's Avatar
MADinAK
St. Jude Donor '06-'07-'08-'09-'10,'14
Well that's not true. I had mine replaced a year or so ago at Safelite. I have HUD and the windshield did not come from GM. All the markings were different. The replacement does say HUD and something about GPS or satelite. Can't remember exactly but they made sure I got the right one. I believe there are 3 different versions available. They did a great job and the replacement is more resistent to chips than the OEM one. Before replacement I had four chips filled. This one has been hit three times and has yet to chip. Total cost? $666 to my insurance company - Geico. Just my .02.
To Front Window Replacement
