Eagle Eye's LED tail lights... what am I missing here???
Old Jan 19, 2010 | 07:44 AM
Uncle Meat's Avatar
Uncle Meat
Default Eagle Eye's LED tail lights... what am I missing here???
So yesterday was finally nice enough to back the Z out of the garage and swap out my stock tails with a set of LED tail lights from Eagle Eyes.
Take a look at the picture below. The top plug is the stock female from the wiring harness and the bottom is the male from the LED tail lights. As you can see they aren't going to mate up at all. Of course this kit came with zero instructions too. Just a single sheet of paper stating that if any of the lights didn't work to disconnect them and reverse the plug.
Suggestions?
U.M.
Old Jan 19, 2010 | 10:31 AM
Wah's Avatar
Wah
I'm going to venture a guess here as I never did this before.
Judging from the picture, I believe you unplugged a connector that's way upstream. Look at the (OEM) bulb connector/carriers, I believe the Eagle Eye's plugs into them.
Old Jan 19, 2010 | 11:02 AM
Zoxxo's Avatar
Zoxxo
You're missing the "between" piece.
Take one of your stock taillamps and remove the socket (that holds the bulb) from the lens. Remove the bulb from the socket. Now look at all the pieces carefully and the light (as it were) should dawn on you
The LED lamp socket plugs into the place where your stock BULB plugs in.
Look at this pic:
http://www.gmpartshouseusa.com/partl...layCatalogid=0
Z//
Old Jan 19, 2010 | 12:21 PM
Uncle Meat's Avatar
Uncle Meat
That's the connector that attaches directly to the tail light assembly.
Look at this pic:
Z//
So using the diagram your referenced in your post I should be trying to interface the Eagle Eyes plug with item #2 or #3 instead of the plug marked #4?
U.M.
Old Jan 19, 2010 | 12:45 PM
Zoxxo's Avatar
Zoxxo
U.M.
#3 is the BULB
#4 is the wiring harness
#2 is the thing you plug the LED plug into (the only thing it *will* fit.)
Just think of your LED units as replacement BULBS.
Z//
Old Jan 19, 2010 | 01:10 PM
Uncle Meat's Avatar
Uncle Meat
#3 is the BULB
Z//
Roger that... I guess it would make too much sense to put a plug on the LED tails which mates with the stock wiring harness plug!
I'll yank the bulb bases out of the housings and plug in there... honestly never even thought about trying that! I figured the stock tail lamps used standard style bulbs with a round base. Never crossed my mind they used a spade style bulb hence I never pulled them apart.
Thanks.
U.M.
Old Jan 19, 2010 | 01:50 PM
Zoxxo's Avatar
Zoxxo
It makes sense, for sure. It would also cost mucho bucks since that connector doesn't have a male counterpart available on the open market. The LED tail lamp maker would have to custom order those and at such low quantities it would be prohibitively expensive. Their solution is inexpensive and easy enough to deal with.
Z//
Old Jan 19, 2010 | 02:06 PM
Uncle Meat's Avatar
Uncle Meat
Z//
I suppose so. They could at least put some instructions in the box for idiots like me...
U.M.
Old Jan 19, 2010 | 05:30 PM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
Can we get pictures of your led lights installed? Where did you buy them from and how much were they?
GeorgeVee
Old Jan 19, 2010 | 08:31 PM
Pack Leader's Avatar
Pack Leader
Dee dee dee
Old Jan 20, 2010 | 05:05 AM
HC Mechanic's Avatar
HC Mechanic
U.M.
Man don't sweat it, the first time working on something your unfamiliar with stuff like this always seems to come up
I was thinking of going with some LED's in the rear also, if there's something quality available that is...
Would appreciate some pics if you get a chance
Old Jan 20, 2010 | 07:28 AM
Uncle Meat's Avatar
Uncle Meat
Sure, I'll shoot some tonight if I get time. You can also go look at the following thread posted by ncvette_1FUNRIDE. He added these exact same LED tails to his car. His Vette is Cyber Gray just like mine so my pictures when posted should look just like his I would imagine.
http://forums.corvetteforum.com/c6-c...-way-pics.html
That auction site which shall not be named... $279.
Originally Posted by Pack Leader
Dee dee dee
Yup! I'm really not normally that technically challenged...
Typical brain fart on my part. I'm a firm believer in the RTFM principle unless there isn't one... then evidently I go dumb quick!
Will do.
U.M.
Old Mar 31, 2013 | 08:16 PM
The_Tibulator's Avatar
The_Tibulator
I ended up calling when I installed mine. Can't believe there are no instructions. I can't remember what the numbering meant, but it wasn't what I thought it meant.
Old Mar 31, 2013 | 08:55 PM
Zoxxo's Avatar
Zoxxo
It's been a while but if I remember correctly the numbers refer to "inboard" and "outboard" as they are not the same shape. I went through this when I installed them in my wife's car. So you should have L1, L2, R1, R2. Sorry, but I *really* forget which is which. The lamps should pretty much "drop in" to the body. If you have to force it in any way then that's the the proper way.
I could be totally wrong here but that's what my inner voice is telling me to say
Z//
Old Mar 31, 2013 | 10:02 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Z//
You can get the inside and outside lights mixed up but you can tell its wrong when you stand behind the car with the lights on...it looks like the car is cross eyed when they are incorrect place. It's important to get them in the right place or they look like they are not working from behind.
Old Mar 31, 2013 | 10:17 PM
montereyred's Avatar
montereyred
do you have a tele number? i looked all over all the correspondence I recd from eba* and the seller and NOWHERE did I find a tel #
Old Apr 1, 2013 | 06:12 PM
corvettej's Avatar
corvettej
St. Jude Donor '13 thru '24
You unhook the wrong plug, the plug you are holding in hand for the eagle eye plug into the bulb holder of your original light once you remove the original bulb. Do it like a bulb replacement instead of a taillight replacement, push it in until it lock in place.
Suggestions?
U.M.
To Eagle Eye's LED tail lights... what am I missing here???
Old Apr 1, 2013 | 06:19 PM
Zoxxo's Avatar
Zoxxo
Originally Posted by montereyred
...email back from a vendor and he tells me that the two eagle eyes taillight housings with a "1" sticker on them are the outer location lenses. the 2 lenses with a "2" sticker on them are the inner(closest to liscense plate) location lenses
I thought that was it!
Z//
Old Apr 1, 2013 | 06:22 PM
SoSlow1's Avatar
SoSlow1
Geaux Tigers!!!!
St. Jude 15 Year Donor
St. Jude Donor '08 thru '26
GeorgeVee
Here are mine I bought from the auction site..
Old Apr 1, 2013 | 06:41 PM
JCtx's Avatar
JCtx
After spending hours on the inet I finally got an email back from a vendor and he tells me that the two eagle eyes taillight housings with a "1" sticker on them are the outer location lenses. The 2 lenses with a "2" sticker on them are the inner(closest to license plate) location lenses.
Mine had the '1' sticker on the left side tails, and the '2' on the right side ones. And both left and right tails have identical markings, so really doubt they're any different.
Anyway, I think the important thing is to install the left ones with the 'L', and the right ones with the 'R'. It's difficult to find the letters, but just look for them. And yes, they're pretty bright, especially at night. But not brighter than some Cadillacs, so I'm happy with them. That's exactly what I wanted. Now all I want is the CANbus LED amber bulbs I'm about to order for the front bulbs work without hyperflashing. That worked with my CANbus BMW bike (rear LED board with built-in resistors, and CANbus LED bulbs in front), so hope it does on the Vette too.
