Lowering Bolt Bushings
Old Jan 25, 2010 | 08:34 PM
03BlkZ's Avatar
03BlkZ
Default Lowering Bolt Bushings
I have pulled my wheels off to put new tires on and I decided I wanted to raise the car up a little since it is slammed. I noticed that the domed bushing on the rear bolt on the passenger side is about half gone and the driver side is all in tact. Can I buy and replace the bushings? Also, is there a write up somewhere that goes in depth on how to raise the car back up some?
Old Jan 25, 2010 | 10:51 PM
corvette dave's Avatar
corvette dave
Plenty of write-ups on lowering/raising. Search should find one.
There is no need to replace the bushing that I assume was cut.
Process is very easy.
You must raise the end of the spring to release pressure before you turn the bolt. Do this with a separate jack or lower the spring onto a block of wood or something to accomplish the same thing.
Turn the bolt with a 10mm wrench clockwise to raise the car.
If the bolt will not turn do not force it. The head will round very easily.
Squirt some type of penetrant onto the bolt threads and try again.
If it still won't turn make sure the rubber bushing is separated from the lower control arm. Raise the spring more until it does and/or use a screwdriver to pry it loose.
Good luck with it.
Old Jan 26, 2010 | 08:09 AM
Justasheet's Avatar
Justasheet
I wonder why they were uneven like that? You can replace them if you want with Delrin bolts by HardBar. Just cut out the old stock ones and the new HardBar's are 2 pieces. The bolt threads in from the top and into the bushing on the bottom. Just use some lock tite in there. Then adjust for the desired height.
Old Jan 26, 2010 | 07:53 PM
03BlkZ's Avatar
03BlkZ
Good luck with it.
In the rear with the car up in the air I can grab the bolt and turn it with out having to take any load off it with a jack. The entire bolt just moves about freely and I can even move it up and down. It this right?
Old Jan 26, 2010 | 08:09 PM
Justasheet's Avatar
Justasheet
Where are you jacking it from in the rear? Are you on the leaf spring? There should be a load on top of it namely the spring which you must lift off of the bushing. Just wondering.
Old Jan 26, 2010 | 09:16 PM
03BlkZ's Avatar
03BlkZ
I am on jack stands and no where near the leaf!
Old Jan 26, 2010 | 10:06 PM
Nasty C6's Avatar
Nasty C6
I have the 2 rear pieces for sale in good shape if you need to buy some newer ones in good shape. I'm changing my fronts now, they are smashed from my heavy iron block and a lot of high speed runs, my rears look good..
Old Jan 27, 2010 | 08:24 AM
Justasheet's Avatar
Justasheet
Anyone here explain this? Can you do the same on the other side as well? How did the car ride?
Perhaps shoot http://forums.corvetteforum.com/memb...3-cmy-six.html a PM. He's helped me out of a jam.
Old Jan 27, 2010 | 09:08 AM
03BlkZ's Avatar
03BlkZ
Both rears are like this. When I reached in to look at the bushings I thought it was odd that I could move them up and down and spin them by hand. I will snap a couple pics when I get home this afternoon. The car actually rides very good. When I first drove it I expected an extremely rough ride like all other lowered vettes I have been in but I was very surprised in how smooth it was.
Old Jan 27, 2010 | 09:25 AM
Justasheet's Avatar
Justasheet
I don't know bro. There are many here on this forum with way more knowledge than I. I just know what I see on my car and read all the posts on how to lower the Vette before I did mine.
Old Jan 27, 2010 | 10:51 PM
corvette dave
I'm a little confused. You talk about turning the bolt freely and moving it in and out. Then you talk about doing the same thing with the bushing. Two different parts, Please clarify.
The bolt should not move about freely in the spring. I am not referring to turning in the threaded shaft.
With the car in the air and nothing under the spring I don't see any way the bushing would not be touching the lower control arm.
Old Jan 28, 2010 | 06:08 AM
03BlkZ's Avatar
03BlkZ
I got home late last night and was unable to take pics so I will try again today.
Old Jan 28, 2010 | 09:42 PM
03BlkZ's Avatar
03BlkZ
Ok, I just went out in the garage and shot some video of me moving the rear bolts with the car on stands and the wheels removed. Hopefully this will help to clear up any confusion on my original question.
Passenger rear:
Driver rear:
Old Jan 28, 2010 | 09:47 PM
03BlkZ's Avatar
03BlkZ
The video was way better on my camera. I may try again tomorrow to get better video.
Old Jan 28, 2010 | 10:59 PM
corvette dave
I see no video. Just a picture.
Old Jan 29, 2010 | 06:08 AM
03BlkZ's Avatar
03BlkZ
click on the pics and they are videos
Old Jan 29, 2010 | 06:54 PM
03BlkZ's Avatar
03BlkZ
Here is another attempt at a video!
This is with car opn stands and wheels removed.
To Lowering Bolt Bushings
Old Jan 29, 2010 | 08:19 PM
Justasheet's Avatar
Justasheet
What year is your car? My C6 looks nothing like the one in your video.
Old Jan 29, 2010 | 08:23 PM
03BlkZ's Avatar
03BlkZ
Old Jan 29, 2010 | 11:20 PM
corvette dave
When I click on them it doesn't go to video. Just enlarges then goes back to normal.
Took me a while but I think I figured out your question. You have a C5 which is different from the C6. Since this is the C6 section I assumed your car was a C6. Never assume.
The C5 rear lowering bolts are different than the C6. To raise or lower the C5 you have to buy longer or shorter bolts. There is some adjustment but not much. Might be enough to raise yours.
To raise the car just tighten the rear bolts (make them shorter). To raise the front is the same as the C6.
