Fluid Help Please ( Tranny/Diff/Clutch/Brake )
Old Jan 28, 2010 | 03:07 PM
Richor's Avatar
Richor
CF Lifetime Member
Default Fluid Help Please ( Tranny/Diff/Clutch/Brake )
List of factory replacement/upgrade fluids for Z51 Manual Transmission :
LIST UPDATED - THANK YOU SUBDRIVER
My recommendation for the C6 Z51:
Transmission: AMSOIL Torque-Drive Synthetic Transmission Fluid 4 QUARTS (Product Code ATD1G)
(This is a Dexron III fluid that is the correct spec for the Tremec Manual in GM applications - I use this fluid in my 02 Z06 on the track and used it in my recently sold 06 CTS-V)
Diff: AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 (Product Code SVGQT) 3 Quarts
Note that while the Severe Gear 75w90 comes with friction modifier in it, and I do not need extra in my 02 Z06 (or my 06 CTS-V) most C6 owners report needing more modifier to prevent diff chatter. I recommend one bottle of this:
AMSOIL Slip-Lock Differential Additive (Product Code ADATB) 1 Bottle
Also, for the DIYer: AMSOIL Hand Pump (Product Code G2039)
Brake/Clutch Fluid: AMSOIL Series 500 High Performance DOT 3 Brake Fluid
AMSOIL Series 600 DOT 4 Racing Brake Fluid 1 Bottle for clutch fluid ( 12 oz ), 1 Quart for a flush flush ( 1 quart = 4 12 oz Bottles )
Note that GM specs a DOT 3 brake fluid. If you are willing to step away from that recommendation, the DOT 4 is the better fluid and I use it in my Z06. DOT 4 is also the right fluid for the clutch.
I use and recommend this grease for those few applications I need grease:
AMSOIL Series 2000 Synthetic Racing Grease, NLGI #2
(Very resistant to high heat loads) ( 1 Bottle )
Old Jan 28, 2010 | 03:14 PM
Xwet's Avatar
Xwet
Originally Posted by Richor
About to order fluids, before I do I just wanted to double check I am getting the right ones :
Differential - Red Line Synthetic Oil 50304 - Red Line MT-90 Transmission Gear Oil
http://www.summitracing.com/parts/RED-50304/
Transmission - Royal Purple 01320 - Royal Purple Max ATF
http://www.summitracing.com/parts/RPO-01320/
Brake Fluid – Motul RBF600 Synthetic DOT 4 Brake Fluid
http://www.amazon.com/Motul-RBF600-S...4708414&sr=8-2
Clutch fluid - GM Super Dot 4 Brake Fluid
http://paceperformance.com/index.asp...D&ProdID=91000
Redline water wetter -
http://www.amazon.com/Red-Line-80204...4&sr=1-1-spell
Also, I could not find the right lubricant for the rear toe end link Z51
Does everything look right? and does anyone know how many of each I should get?
Thanks Guys !
Forum members speak highly of Amsoil products. Try their web site.
They should have everything you need.
Old Jan 28, 2010 | 05:47 PM
acapelladave's Avatar
acapelladave
i have gone with all the products u listed but i loved amsoil the first time i used it
Old Jan 28, 2010 | 06:00 PM
Richor's Avatar
Richor
CF Lifetime Member
Dave,
Is amsoil more of a factory replacement or high performance like the fluids above.
Also, so I guess that means all the fluids I listed are the right specs? Just want to make sure I order the right stuff.
Thank you !
Old Jan 28, 2010 | 06:18 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
I would like to jump in here if I may. For your 2006 Z-51, I would order the Amsoil Severe Gear 75W-90 for the diff. You can add the LSD fluid if you want but many have gone without and had no problems. Their Severe gear fluid is the best IMHO.
Since it looks like you have an auto based on your selections, I would go with the Amsoil ATF, use their ATF not ATL, ATL is their Dexron VI spec'd fluid, ATF is Dexron III compatible.
For brake AND clutch, you can use Amsoils DOT4 brake fluid for both. It's a good product and not as expensive as some but more than others..Just so you know, DOT3 is specified for these systems from GM but DOT 4 would be an upgrade IMHO.
As to Redline water wetter, I have used it and saw no benefit. But that is me, if you want to use it I see no issues.
Last of all, if you cannot find an Amsoil dealer close to you, contact user Subdriver on these forums. He is a good resource and last I remember he is a forum sponsor.
And to answer your other question I feel Amsoil is a high performance upgrade over the factory fill fluids.
If I can help any more, let me know.
Old Jan 28, 2010 | 06:41 PM
Richor's Avatar
Richor
CF Lifetime Member
^^ I have a 6 speed manual
oops didnt notice the fluid I selected was ATF
What do you reccomend for the manual tranny fluid from amsoil
Thanks so much for taking the time to respond
Old Jan 28, 2010 | 06:52 PM
Richor's Avatar
Richor
CF Lifetime Member
Update Original Post. thanks.
Regarding the amsoil Manual tranny fluid/ Which one do you all recommend?
Manual Synchromesh Transmission Fluid 5W-30
Manual Transmission & Transaxle Gear Lube 75W-90
Super Shift Racing Transmission Fluid SAE 10W
Also a recommendation for rear toe end lubricant z51
Old Jan 28, 2010 | 07:46 PM
ByByBMW's Avatar
ByByBMW
I think this will work, http://www.amsoil.com/mygarage/vehic...LET+CORVETTE+H
And here is a discussion about the grease for the Z51 http://forums.corvetteforum.com/c6-t...nk-grease.html
Hope that helps.
Old Jan 28, 2010 | 08:17 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Richor,
Dropping you a PM and hoping I caught you before you buy to ensure you get the best pricing possible via the AMSOIL Preferred Customer Program, about 25% below retail.
Transmission: AMSOIL Torque-Drive Synthetic Transmission Fluid (Product Code ATD1G)
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 28, 2010 | 08:28 PM
Richor's Avatar
Richor
CF Lifetime Member
Pmed you back. Thanks so much. You answered all my questions . !!!!!!!!!!!!!
Old Jan 28, 2010 | 08:36 PM
ByByBMW's Avatar
ByByBMW
Told you Subdriver was a great resource. He will take good care of you.
Old Jan 28, 2010 | 08:44 PM
Richor's Avatar
Richor
CF Lifetime Member
Yeah he seems great. So far soo good. Thank you subdriver
Old Jan 29, 2010 | 03:22 PM
Richor's Avatar
Richor
CF Lifetime Member
Regarding the differential additive, I read as of 1/2008 that was no longer required. .. any 1?
Old Jan 29, 2010 | 03:48 PM
ByByBMW's Avatar
ByByBMW
What Subdriver said, most C6 owners, including me, added a bottle.
Old Jan 29, 2010 | 04:34 PM
Richor's Avatar
Richor
CF Lifetime Member
Ok thanks.
I am trying to figure out how much worth of fluids to order
For the differential I read I need 3 Quarts
Transmission fluid 4 Quarts
1 Bottle of brake fluid for the clutch
Old Jan 29, 2010 | 04:48 PM
ByByBMW's Avatar
ByByBMW
Ok thanks.
How much for the transmission fluid as well as how much brake fluid do I need for a complete tech1 flush and clutch fluid change? thanks bmw
If that link to the Amsoil page worked, it should show you how much diff, tranny etc fluids you need.
As to the brakes I really don't know, but when I changed my fluids to DOT4, it took about a quart. The clutch system is actually a fairly small, fluid wise, system. I assume you are going to do a drain and fill the clutch master cylinder only so a pint would probably be enough for that, and you can do it 3-5 times. Just use up all the fluid in the container quickly since brake fluid absorbs water and you don't want that in your clutch/brake systems.
Did that help?
Old Jan 29, 2010 | 04:54 PM
Richor's Avatar
Richor
CF Lifetime Member
Helped alot thanks. I am actually having the dealer do the whole flush due to the tech1 necessity. They said about a quart as well. Thanks !!
Im going to update the first post with the quarts and types of fluids incase any one else ever asks
To Fluid Help Please ( Tranny/Diff/Clutch/Brake )
Old Jan 29, 2010 | 05:03 PM
ByByBMW's Avatar
ByByBMW
Any time, we almost all are here to help.
Old Jan 29, 2010 | 05:12 PM
Richor's Avatar
Richor
CF Lifetime Member
Well I am sure that soon enough I will be paying it forward once I learn more about our vehicles. thank you sir.
Old Jan 30, 2010 | 10:26 AM
C66 Racing's Avatar
C66 Racing
BMW - thanks for keeping up with Richor yesterday while I was at work. Ended up calling him on my drive home and answered all his questions.
Though I explained it to Richor on the phone, sharing here for anyone reading this thread. The above quote is based on GM's fluids. For anyone following C6 diff chatter threads, this will be old news. When the C6 came out, many owners (most?) experienced diff chatter, normally most evident in sharp slow speed turns like coming out of a driveway, in parking lots etc. The GM fluid, even with additive, did not have the appropriate friction characteristics for the C6 diff. Someone tried the AMSOIL Severe Gear 75w90 with one bottle of additive years ago and found it cured the diff chatter issue and after many thousands of miles it stayed cured. Circa 2008 GM came out with a new fluid, the Dexron LS 75w90. This fluid has significant amounts of friction modifier already in it and thus the statement above that indicates additive no longer required. A little bit of a misnomer as the modifier really is still required, its just in the gear lube now. At something like $28 a quart, the GM fluid is about three times more than the Preferred Customer pricing of the AMSOIL Severe Gear.
Though GM changed their fluid, AMSOIL has not and for those using the AMSOIL Severe Gear 75w90 in the C6, I recommend one bottle of additive. Note that as I mentioned above, I run this same fluid without extra additive in my 02 Z06 without diff chatter, and similarly used it in my 06 CTS-V that I recently sold without extra additive and again, no diff chatter. But, the C6 diff clutch plates, for whatever reason, behave differently.
Richor - thanks for the support. I appreciate it! Good talking with you yesterday.
