Brake fluid volume??
Old Jan 29, 2010 | 11:21 AM
Dan Wendling's Avatar
Dan Wendling
Default Brake fluid volume??
What is the brake fluid volume for a 2010 GS (same as Z06 I think)? I want to purge my OEM fluid and replace it with Castrol SRF but have no idea how much to buy? Expensive so, need to only buy what I need.
Old Jan 30, 2010 | 10:13 AM
CMY SIX's Avatar
CMY SIX
when I did my 06, put SS lines on I had two quarts on hand, I sucked out the res. and put new in and started bleeding with a "power bleeder" as you can't tell new from old. you're guess is as good as mine. I used about 1 1/4 quarts give or take
Old Jan 31, 2010 | 02:56 AM
Chris_B's Avatar
Chris_B
It will take between 1L and 1.5L for a full flush. If buying 500mL bottles, you will need three on hand.
Chris
To Brake fluid volume??
