Engine Noises
Old Jan 31, 2010 | 04:55 PM
Chaser720's Avatar
Chaser720
Default Engine Noises
Ive got a loud metal ticking sound coming from the engine. Also after running through a gear, if i do not shift and allow the RPMs to fall back down i get a loud squeak that sounds like a belt slipping.
Ive searched a bit and from what ive found it looks like a loose harmonic balancer in the crank pulley but it doesn't make any squeaking on acceleration.
Any help would be great.
Old Jan 31, 2010 | 05:41 PM
VET4LES's Avatar
VET4LES
I see you have an 05. If it's an early VIN you should stop driving it and take it to the dealer ASAP. There is a TSB about it. If you do a search in the FAQ section you should find out all you need to know about the problem.
Old Jan 31, 2010 | 06:22 PM
Chaser720's Avatar
Chaser720
So from what i described it sounds like the Crank Bolt loosening or the harmonic dampener?
Old Jan 31, 2010 | 06:24 PM
torquetube's Avatar
torquetube
If you suspect the pulley, have a look at it with the engine running. Is it wobbling around like a paint mixer? Does the belt appear to be riding up against the rear flange? Is the pulley (gulp) kissing the front cover?
Old Feb 1, 2010 | 01:39 AM
Chaser720's Avatar
Chaser720
Will do tomorrow.
Also got the squeaking noise today after hitting a bump in the road. Engine was in gear deaccelerating but was silent until the bump.
Old Feb 1, 2010 | 01:48 PM
Chaser720's Avatar
Chaser720
Pulley is for sure wobbling a bit. And it may be a little bit back but cant really tell.
Old Feb 1, 2010 | 05:55 PM
Chaser720's Avatar
Chaser720
Mild squeaking at idle... think this one is pretty much concluded.
Appt. for the dealership tomorrow
Old Feb 2, 2010 | 12:41 PM
Chaser720's Avatar
Chaser720
Back from the dealership. Said it was the idler pulley so big relief there. They wanted $350 to replace both idler pulleys and both belts. lol Laughable so i payed the diagnostic and left.
To Engine Noises
