Brakes
Old Feb 1, 2010 | 11:00 AM
anabolicelvis's Avatar
anabolicelvis
6th Gear
Default Brakes
Hello,
Anyone know how long the Front and Rear brake pads and rotors usually last on a 2007 C6? No hard driving just 20 mile commute to work. My 2007 has 32,000 on it currently. Brakes feel great but just wanted to be proactive.
Thanks,
Old Feb 1, 2010 | 03:11 PM
CMY SIX's Avatar
CMY SIX
they last about as long as any other car
Old Feb 1, 2010 | 03:56 PM
tdelena's Avatar
tdelena
St. Jude Donor '12, '14-'15, '17, '20
I would change them now. Mine lasted 28k and one of my rear pads tapered badly and it was on the inside. I was very close to the metal.
Old Feb 1, 2010 | 03:59 PM
anabolicelvis
6th Gear
Default brakes
Thank you for the information.
Old Feb 1, 2010 | 04:46 PM
Bill Dearborn's Avatar
Bill Dearborn
Probably no more than 40K miles. It sounds like most of your driving is on a highway with few stops so they may last longer. You should check the pads though. They do taper and one end could be worn more than the other end. If they need to be replaced you can still use the rotors as long as they meet the minimum thickness requirements specified by GM. If you use OEM replacement pads and the rotors meet the thickness spec and do not have any grooves in them you will not have to do anything to them. Just slap in the new pads and go.
Bill
Old Feb 1, 2010 | 04:51 PM
anabolicelvis
6th Gear
Thanks Bill. Good information. I appreciate the advice.
Old Feb 1, 2010 | 07:33 PM
timd38's Avatar
timd38
Bill
I would also bleed the brakes to get rid of the old brake fluid.
Old Feb 1, 2010 | 09:19 PM
VET4LES's Avatar
VET4LES
It all depends on how you drive. Brakes can last 70,000 miles and more. The rear brakes on my XJ8 have 70,000 miles on them and still look good. I changed the fronts at about 45,000. My C6 has 24,000 miles and they all still look like new.
Old Feb 2, 2010 | 01:47 PM
anabolicelvis
6th Gear
Thanks very much for the info.
Old Feb 2, 2010 | 01:48 PM
anabolicelvis
6th Gear
Ok great thanks.
To Brakes
