DTE differential
Old Feb 6, 2010 | 11:16 AM
Boomer111's Avatar
Boomer111
Default DTE differential
Interesting that the chatter is completely gone with this change. Even with the OEM, fluid change and figure 8's, I still experienced some mild chatter at take off. Now with the Differential swap it is completely gone, sounds like a normal car. The swap is new and not broken in yet but I can already feel that it was the right decision going with 4.10's.
Old Feb 6, 2010 | 11:58 AM
CMY SIX's Avatar
CMY SIX
what needs to "break in" with gears? you apparently had bad "clutch packs" in your old diff, or damaged it trying to launch it or do burn outs like john force, Because the rest of us only had the "chatter" when we were turning and in my 06 the "new" fluid worked perfectly! instantly! and I recently went to Amsoil and still no noise, say good by to your MPG
Old Feb 6, 2010 | 12:25 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
Another positive post from CMY SIX...
Congrats on the new DTE diff Boomer!!!
Old Feb 6, 2010 | 12:47 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
just for info, how much DO you lose in mpg by going to 4.10 vs. 3.42 (I presume that's what you had before)? I would think it's somewhere in the 3-5 mpg range, but that's just a guess.
Old Feb 6, 2010 | 12:59 PM
Boomer111's Avatar
Boomer111
Well I to had amsoil in the oem diff, with the added friction modifier. The clutch packs could very well have been the problem.. I know DTE upgrades the packs in their stage 2, which is what I have. Also remember I said mild chatter actually passengers could not detect it. I am very sensitive to sounds and vehicle feel. ( This is just a by product of driving big rigs for a long time ) I am not bragging here most long time drivers develop this sense if they have a brain that is switched on.
Also I have never launched or burned out, ever in this car. Two yrs. old. I am a very smooth driver, 33 yrs Commercial experience. My brakes last forever. My 96 4 runner with 170,000 miles still has original pads and rotors.
Weekend driver so milage is not a concern. For trips I expect to maybe loose 2 max. I was getting 29 so no bigger for me.
With 80,000 lbs under you it is all amout smoothness on the road especially in the twisters, brakes get hot real fast.
The brake in procedure is more of heat cycling for 350 miles keeping under 3,000 rpm and no wot.
Neumonic 2002......ya thanks for the post.
Old Feb 6, 2010 | 01:13 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
thanks for the info.
Old Feb 6, 2010 | 03:09 PM
HC Mechanic's Avatar
HC Mechanic
Yeah I'll second that! I wish this like one of those new contest shows where you can vote people off the island
Old Feb 8, 2010 | 08:25 PM
Ragtop 99's Avatar
Ragtop 99
I'm down 1 -3 mpg with 3.90s. I have the DTE Stage 2 rear too. If you want to try it out once some of the seemingly non-stop snow melts , shoot me a PM.
Old Feb 9, 2010 | 01:01 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
thanks! it's probably too fast for me with the gears. I'm used tomy sedate stocker. very sedate with five and half feet snowbank in front of it.
To DTE differential
