First Time Corvette Owner, FURIOUS...CODESSSSS
Serive Engine Soon
Service acitive handling system
Service Fuel System
Low Fuel (had a full tank)
Service Traction Control
So I would turn it off and it'd come back on then go away. I take it to the local GM dealership,(it went into limp mode I guess, cuz it would only stay in second gear, I'm guessing, and wouldnt change gears) who were really nice people. I have a 3 year extended bumper to bumper warranty. They hook it up to the computer and check it. They tell me that they found 48 "historical codes". They said that they couldnt find any "current codes". So they cleared them and told me to drive around in the area of the dealership to see if they come back on so I could whip in there and they check it immediately. Well of course the car worked flawless. This was yesterday. So I wake up today to go out and see if its gonna throw a code. Sure enough it did, did all of the above things on the dash display. Went into limp mode again. Meant to add, this morning when I tried to crank it, you push the button and everything goes off, then it'll pop right back on. On these mornings the nav unit or in the area of the nav unit, whether behind it or whatever will make this wear noise like the computer of something is funny.
So I take it to autozone to see if they could get a current code, they found the following:
P0700 Transcontrol system malfunction
U0073 Control Module
Now even the guy at autozone said that its nothing serious but that its just sensors not reading back to the computer.
Does the historical codes not show what the codes were?
Checking recent work done that was included in the papers showed they had the steering wheel clip installed on the telescopic steering wheel. there were 2 other times codes occured, but the dealership fixed those.
Now, I have wanted a corvette my entire life and it has been my dream car, now that I have it, all these codes are making me furious to the point that I am tempted to sell it, because these malfunctions are really making me lose alot of interest in this car Fast.
Is this somethign that I get to look forward to? If so it'll be gone next week..adn I havent even bought the tag for it yet.
I'm know I'm venting to you guys but its driving me insane because I Really want to enjoy this car but I cant in fear of getting stranded.
ONE MORE THING, its NOT the batter, I bought a new optima on Wednesday. SO please, I'm asking for all of your help, because I really really love this car but don't want to keep going through this.
please help from a first time corvette owner!
I think the P0700 is a Transmission Control Module for your automatic transmission.
However, the U0073 is for "Network: Control Module Communication Bus Off", and can refer to any computer in the car (BCM, EBCM, PCM, HVAC, Radio, RCDLR, TCM, VCIM, etc., etc., etc.)
So....It may be due to a problem with the TCM, or any other computer module in the car.
Butt......if the battery is not a problem, I would start out by checking to make sure everything is grounded properly. Make sure the battery cables are connected, battery grounded securely, cables to the starter and alternator are secured, and then any other ground you can find - make sure it's tight. With your TCM code, I'd definitely check to make sure all wires to/from the transmission are connected securely.
A loose ground can often cause intermittent problems such as you're experiencing.
Bob
I would still try another battery. Often "new" batteries are not in good order.
Also, I would then ask the dealer to reflash your tcm, bcm and ecm. Cant hurt. Takes little time. If it still happens:
then I would go with a a new ecm and or bcm.
These cars go crazy when the battery is not in good order so you still might have a bad battery.
If you are in Nor Calif I have an extra battery that has been maintained on a charger that you are welcome to try. Other than the battery, you could have a bad computer--that simple. Is there any history of the computers being changed? This car could have been massaged by tuners in the past that messed up the computers. Just a thought.
Also the car has several ground connections. They should be checked also. Make sure the battery terminals are tight and making good contact.
Let us know
I'd take it back to the dealership and let them handle it, especially if it's under warranty. I'm thinking it's a bad connection somewhere on one of the modules. Maybe the BCM (body control module) or the PCM.
Keep us posted.
I'm trying very hard to stay positive, guess I'm just dissapointed at not being able to enjoy it they way I want to.
I really appreciate the battery offer KnKali, but I'm all the way over in Bama. I'm going to go out and check the grouns that I can find now. If you have any other things I might could do, please let me know. Thanks in advance!
I am a Technician, but I do not work on GM products for a living. Most of the Bus related issues I deal with are caused by a defective control module or voltage supply. One malfunctioning control module on a bus system can take down the entire bus and result in the multiple warning lights you are seeing. An intermittent Bus issue like this can be hard to track down. That is why the dealership cleared the codes. They wanted to see what was coming back first to try and narrow down the cause of the issue.
This problem started happening before you put the new battery in or after? If a problem occurs after a recent repair has been done, I always look first at what was done to the car. Something could have been knocked loose, pinched, etc. I also always look for signs of accident damage/collision repair. I cannot tell you how many body shop nightmares I have seen over the years.
I would recommend taking the advise of the Autozone guy with a grain of salt. Go back to the dealership and let them fix it. You have a warranty, and whatever is causing the problem is likely covered. I am sure there is just one bad part causing all these issues. Good luck and let me know if I can help.
Andy
If you have a service manual or someone can tell you where the ground points are on the c-6 check them out, sorry I don't have a c-6 service manual at this time.
Went for a ride down the road and no service codes. However, I went to put it in competitive drive mode adn it won't do it. It'll only cycle between traction control on and off, regardless if I hold it down for the 5 or 10 second interval etc. So that means that something is still wrong with it. Checked the batter connection, they were good, but cleaned them again to be safe.
Checked the alternator and starter connections and those were good.
The issue with not being able to put it into Comp mode or turn AH off completely is often due to a problem with the tire pressure sensors.
What does your DIC say about tire pressures? Is it "xx psi" or is it displaying actual pressures, such as "31 psi"?
Have you had a DIC message that says "Service Tire Monitor"?
The tire pressure sensors must be properly programmed into the TPMS computer in the car (which is actually part of the RCDLR module).
You say you replaced the battery. Disconnecting the battery will drop the last known pressures out of the TPMS, but shortly after you start driving they should update to indicate correct pressures in the DIC.
You may just simply need to have a relearn procedure done to properly register the unique ID# of each sensor into the TPMS computer in the car to get the AH/TC button to work correctly.
Bob
I had similar codes and symptoms,
Remove or disconnect or re-install to stock anything aftermarket that is electrical.
Aftermarket radio
Aftermarket accessories with switches
The autozone store scanner can only read powertrain codes which are common among all cars. Your problems are in the GM enhanced area and their scanner can't even see them. Same thing with all modern cars. It is a waste of your time to go to the store if the CEL isn't on.
C6s prevent competition mode from being engaged if the TPMS system isn't working properly. As one of the posters above said check your tire pressure readings for xxx's although it seems there would have been a tpms service message if there were xxx's. Did you get a low or high tire pressure warning? They shouldn't have gotten screwed up by the battery problem but they may have. A tire shop can reprogram them if you think they aren't registered correctly with the car. Usually these things would generate a Service Message on the DIC so if you haven't seen one then it is unlikely they are the source of the problem but checking them is cheap and fast.
By the way is the MIL still lit on the instrument panel?
Bill
I just now got back from about a 2 hour or more ride to see what it would do, not a single light ever came on but still no comp mode. Going through the set up to look at the tire pressure it shows my left rear tire psi is a "0". It did this a while back too, but then automatically reset itself and still shot out all those warning codes. But as of right now it is on 0. But during the whole 2 hours, it didnt show ANY symptom minus the no Comp mode. But I am fairly certain that in the morning when I get in it to leave, it won't start.
