18x10-11 wheels
Old Feb 9, 2010 | 03:28 PM
timd38's Avatar
timd38
Default 18x10-11 wheels
Here is the deal. I have BBS wheels for daily use, but want to get a set of DOT track tires. That means I need a pair of rear wheels that are 18x10-11, because 19" rears are tires are hard to find. I don't want to spend a fortune on wheels and thought about getting a pair of fronts an widening them, but would prefer wheels made the right size.
Any ideas?
Old Feb 10, 2010 | 10:38 AM
Wah's Avatar
Wah
Try C5 Z06 wheels (18x10.5) or 18x12 replicas.
Old Feb 10, 2010 | 02:50 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Any ideas?
Tim, I did just that. Got some 8.5 fronts on E-Bay and sent them out to
be widened to 18x11. Then got tires which are 305/35/18 which work well
for fitment and great traction. They did however cost $1,350 by the time all was said and done but i like having 2 sets of tires.
Old Feb 10, 2010 | 04:21 PM
craftfox's Avatar
craftfox
where are you guys sending these wheels to be widened? and why are you using front wheels to do this with? the backspacing?
Old Feb 10, 2010 | 04:58 PM
LSCHLEM's Avatar
LSCHLEM
Many of us are sending the wheels to "WELDCRAFT" . The OEM front in my case was a chrome spoke and wanted to match the fronts with the rears and not depend on aftermarket wheels of inferior structural quality. The
8.5" fronts are widened to the inside by 2.5" at WELDCRAFT. Then your tire is actually 12.25" wider rubber and there is no clearance issues. They
sit inside the fenderwell with clearance. I have NITTO55R2 tires and they are great. Actually SPINMONSTER pioneered the idea and has a nice writeup on the whole process. Just do a search and check it out. Leon
Old Feb 10, 2010 | 06:38 PM
ChassisMan's Avatar
ChassisMan
18X10 is standard Z front size, should not be a problem. I have 18X10.5 HRE's on mine.
Old Feb 10, 2010 | 07:15 PM
timd38's Avatar
timd38
Do you know if the Z06 fronts have the correct offset for use on the rear?
I really like that idea.
Update! Z06 fronts are only 9.5".
Old Feb 11, 2010 | 05:41 PM
ChassisMan's Avatar
ChassisMan
Sorry Bro, my bad. I know my wheels are 1/2" wider than stock Z. So they are 18X10.
Old Feb 11, 2010 | 07:52 PM
topend182's Avatar
topend182
Check out the OZ rims on tireracks site. 18x11 and proper offset. They're about $400/ea
Old Feb 11, 2010 | 08:11 PM
timd38's Avatar
timd38
Find them thanks!
Old Feb 14, 2010 | 12:29 AM
HuskerBullet's Avatar
HuskerBullet
Here's my plan when I can afford it....after getting the wide rear fenders, then 18x10's up front and 18x12's in the rear......Toyo's, done deal.
Old Feb 14, 2010 | 04:04 PM
CDN Vette's Avatar
CDN Vette
My friend has a set of widenned c6 fronts for use on rear for sale in the canadian for sale section.
Justkin is his sign in name and in his post he says:
As well I have a set of custom widened stock C6 fronts for the rear.
They have been widened 2.5 inches to 11 inches by Weldcraft in Illinois last fall. They come with a set of 305 MT,s almost new from Arun last fall. This tire and wheel combo keeps your car looking completely stock while increasing traction to close to 600rw.
Do a search on this forum...secret recipe.
I want 1100....open to offers....no lowballing please.
You should PM him if you're interested.
Old Feb 14, 2010 | 04:32 PM
timd38's Avatar
timd38
Thanks!
I don't need drag tires, so for about the same money the Tire Rack has a set of OZ wheels (all four) with the rears being 18x11.
To 18x10-11 wheels
