c6 ZO6 brakes
1. Remove the pad pin bolts (you only need to remove the 2 center pins on the front calipers, and the one center pin on the rear).
2. Remove the calipers.
Most people probably just remove the calipers. The pad pin bolts can be a beotch to get loose.
If you get one-piece pads I think you'll need to remove the calipers.
Why would you turn the rotors??? Do they have a lot of ridges? Will your new pads have different composition?
Even if they're a different pad composition than what you've been running, for the street I just put in new pads.
Bob
Bob
