Trans Brace or not??
Old Feb 20, 2010 | 02:44 AM
Bad News's Avatar
Bad News
Default Trans Brace or not??
I spoke withe RPM transmissions today regarding upgrades for my soon to be 600RWHP. I was already planning on a stage 3 diff as well as a trans brace but they said I dont need a trans brace and it is more for the C5...? I've never hears someone say that a trans brace is a waste or I don't need one. Anyone else have any input? I wouldn't mind putting the cash towards something else if its not needed.
Old Feb 20, 2010 | 10:33 AM
07MontRedcp's Avatar
07MontRedcp
The trans brace won't save the case from cracking but it is supposed to save the the internals from disintegrating. Thankfully, I have no personal experience to back up my info. Supposedly the 2005 C6 is more prone to cracking and I know nothing about the C5.
Old Feb 20, 2010 | 10:46 AM
c6 batmobile's Avatar
c6 batmobile
It wont save you entirely. There was a thread around here somewhere I think where somebody had one and their input shaft still got destroyed when the diff blew. The shop is probably right. Just be glad they arent trying to sell you something you dont truly need. Most places will just sell you it because they are making money.
Old Feb 20, 2010 | 11:49 AM
YLOFEVR's Avatar
YLOFEVR
St. Jude Donor '09-'10-'11
Default Diff brace
May I suggest that you contact Chris or Doug at ECS (forum vendor). I'm not suggesting that you've got improper advice already, but ECS has a diff brace that is quite different from DTE which was designed and manufactured to their own specs. They are a full service shop and not only design and sell them but also build and run some of the fastest C5s and C6s in the country, so they are in a unique position to advise you of these things. Hope this proves helpful to you.
Old Feb 20, 2010 | 03:07 PM
Bad News's Avatar
Bad News
I will give ECS a call as their brace was the one I was originally planning to go with. I did mention the ECS brace to them and they still insisted that it was not needed and a waste of money.
Old Feb 20, 2010 | 07:33 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
The brace is NOT going to save your rear, so to speak. It's purpose is to isolate the damage to just the dif and not allow the carnage to take out your transmission as well. Your dif can/will still crack under the right(or wrong depending on how you look at it) circumstances. When the dif takes out the trans, you're looking at big $$. I've seen it. The brace is supposed to prevent that. Of course I don't know anywhere near as much as RPM or ECS so my word really isn't worth much.
Old Feb 20, 2010 | 07:56 PM
Bad News's Avatar
Bad News
Im definitally not saying someones word is not worth anything. I know RPM is a great company and I do plan on having them build me a diff I was just shocked to hear the a brace is basically usless on a C6. I remember specifically bringing up the issue about saving your tranny in the event that the diff goes but I was told it wouldent help and the trans will still be affected.
Old Feb 20, 2010 | 11:35 PM
k0bun's Avatar
k0bun
Interesting. I have always heard that this was the sole purpose of the brace. Maybe I have been misinformed. Either way, I'm sure RPM will take care of you.
Old Feb 21, 2010 | 05:25 AM
CPG1962's Avatar
CPG1962
Default 2005
I think they are more (or most) appropriately used on 2005 C6's for drag racing
Old Feb 23, 2010 | 07:32 PM
Bad News's Avatar
Bad News
Anybody else?
Old Feb 24, 2010 | 02:41 PM
Bludog's Avatar
Bludog
Old Feb 24, 2010 | 03:57 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
A brace wont stop you from breaking a output shaft, or a pinion, but it will stop the trans from ripping itself from the rear.
This one is on a C5 but we've seen it on the C6's as well. Only on the 6 speeds however. (not to say that it couldnt happen in an auto).
A brace is $399 bucks. A new tranny and rear (no rebuild, becuase you'll have no core) is probably $4000+. You can blow the trans, you can blow the rear, but the likelyhood of exploding both of them is pretty much nil with a brace. To me it's cheap insurance.
I have one on my car, and after 100+ qtr mile passes with 4+k dumps, and who know how many road course days I still have the stock tranny and rear in the car.
Your call tho...
Old Feb 24, 2010 | 07:54 PM
EuroRod's Avatar
EuroRod
If you are talking about the DTE differential brace, it's sole purpose is to to prevent the differential from taking the tranny with it should it grenade. Period. It does nothing to reinforce the case or prevent the differential case from breaking.
Old Feb 25, 2010 | 05:05 AM
Bad News's Avatar
Bad News
When you say it prevents the differential from taking the tranny with it do you mean just the tranny case? I understand the main shaft will still probably go. So basically all the brace does is save the tranny case from going in the event that the diff goes? Sorry im just trying to understand. I know the brace is just cheep insurance but I am trying to safely do my build on a budget so I would much rather save the money if its not needed. I will be at about 600rwhp on dr's and I was planning on doing hardened left & right shafts.
Old Feb 25, 2010 | 08:47 AM
EuroRod's Avatar
EuroRod
Somtimes with a catastrophic differential failure, the unit will move rearward, causing damage to the tranny. The brace prevents the unit from dislodging itself from the tranny. Look at the DTE webste and view the brace. A pic is worth a thousand words.
Old Feb 25, 2010 | 09:33 AM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In V Veteran
Old Feb 25, 2010 | 09:59 PM
Bad News's Avatar
Bad News
Ok so this might be a stupid question but.... I understand that the brace provides a stronger mating between the tranny and rear end and can cause the diff from taking the tranny with it in the event that it goes. But isn't there another housing between the diff and the tranny? I believe this piece is something like $300 or so. So in the event that the diff does go would the worst case be that it takes this other piece with it and not the whole tranny?
To Trans Brace or not??
Old Mar 1, 2010 | 02:37 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In V Veteran
Yes there is.... but by the time that piece breaks, you're still way over the cost of a brace. Not to mention you'd likely be destroyiong internal parts at that point.
Old Mar 1, 2010 | 04:04 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
The main function of the brace is to keep the rear from rotating in the opposite direction of the wheels. You are correct that there is an adaptor plate in the rear of the trans that fits it to the Corvette, but when the rear rips from the trans (in the pics above) it takes the trans shaft (which goes from the front of the trans, all the way threw the rear of the diff) along with it. Since it is not being pulled off straight it has to break the shaft as well.
That shaft is the main shaft that goes throughout the entire trans, so you would need an entire trans rebuild, along with the new rear adaptor plate. The main trans housing may be usable, but the build on the trans alone is going to be way over the expense of a brace, let alone the rear you will need to replace as well.
I hope that explains it easier, if anyone has any other questions, please let me know.
Old Mar 1, 2010 | 05:05 PM
k0bun's Avatar
k0bun
Seen it happen. Although we thought (hoped) it was just the rear, when the car was put on the lift, the shop had to deliver the unfortunate news to the owner that his trans was done too.
