Can wheel studs be re-used?
Old Feb 28, 2010 | 01:40 PM
SgtRod's Avatar
SgtRod
Default Can wheel studs be re-used?
I am planning on replacing a rear wheel bearing and wanted to know if I can just transfer the studs to the new one. They are the DRM studs, if that makes any difference. Changing the wheel bearings in the rear is quite hard so would hate to do it twice so please only respond if you KNOW for a fact.
Thank you!!
Rod
Old Feb 28, 2010 | 02:34 PM
timd38's Avatar
timd38
Well, when I did mine, I replaced the studs. I used the SKF Bearings that Pfadt has. Don't forget to change the axle nut.
Old
New
Old Feb 28, 2010 | 04:39 PM
LEAVINU's Avatar
LEAVINU
Are those the ARP wheel studs timd38?
Just ordered some Friday.
timd38's Avatar
timd38
Yes the are. Lisle tools makes a stud installer that works really well.
To Can wheel studs be re-used?
