i have a ? about push rod length on a ls2 with stock heads not milled stock rockers i installed a comp cam 54-444 with comp push rods 7.40 it seems like it has too much valve lash to me it clicks and clacks at idle to 1500rpm i know there is a way to check the proper rod length but i was thinking of just installing some 7.425 push rods what do you think and what size have you seen run on this combo i think comp cams are smaller on the base circle? thanks for reading this and any advise you have Scott
hey a/c man, 7.425 is usually what everyone runs with a comp cam. yes, they have a smaller base circle. comp has a pushrod length checker tool they sell for about 17.00 i think. 7.430 will quiet it down, but may be a little too tight for performance and smooth running. hope this helps, cranky
I am ordering a cam kit next week and some tell me to order the 7.400 and others tell me 7.425? My installer will check the the length/preload but I don't want to have to wait to send a set back to be replaced by the correct length if I can help it.
7.4 every time, some cams swaps make a little ticking, its just life. we have installed 100's of cams and only about 3-4 times had to use a pushrod different than a 7.4 If your questioning it Check the preload on you lifter that will tell you if you have the right length or not. Now...if you have trick flow heads you need a 7.5 most of the time, but with your ls2 heads you will be fine with the 7.4's with your comp cam, 7.4 is a tad bit longer than STOCK and that makes up for the smaller base circle of the comp cam.
I'm coming to see you this sat. to dyno my car again after installing a new fuel system! hope you can get a little more Muscle out of it then i will meet you guys @ the track Sunday test-n-tune! see if i can beat my old time of 10.32 @ 131mph! bring the video cam thanks Steven for all the help on my car!
