After Battery Replacement?
Old Mar 11, 2010 | 08:35 AM
CCDVRichy's Avatar
CCDVRichy
Default After Battery Replacement?
What systems have to be reset? I know the windows on the cpe have to be re-indexed.What else?
Old Mar 11, 2010 | 08:47 AM
Bandit1's Avatar
Bandit1
Other than the window indexing, that's it. Check your clock in the radio/nav to see if it retained time. Just swapped mine out a month ago and everything powered back up and memory selections retained settings. However, some guys have indicated that they had to reset some memory selection settings (i.e., seat(s) and mirror(s)). You will definitely lose the temporary memory readings in the DIC such as average MPG.
Old Mar 11, 2010 | 08:55 AM
lsbrodsky's Avatar
lsbrodsky
Yeah, but when I did mine the mirror positions needed to be reset and reentered into memory, too.
Larry
Old Mar 11, 2010 | 11:30 AM
CCDVRichy's Avatar
CCDVRichy
Bandit1,thanks very much.
Old Mar 11, 2010 | 01:24 PM
PDXPorkchop's Avatar
PDXPorkchop
Default Battery change out
Can you avoide the problems if you hook up the battery tender to the Cig. plug inside the car. So there is power, while the battery is removed?
Old Mar 11, 2010 | 07:00 PM
saplumr's Avatar
saplumr
That's probably not a good idea. I think it would be safer and easier to reset a couple of things.
Old Mar 12, 2010 | 10:52 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The last time I went to Sears(?) for a battery in my Camaro, they plugged something into the cigarette lighter hole and "held" my radio and junk while they swapped out the battery.
Actually, if you have it, use it but it's not that big a deal to reindex and reset the mirrors and seat. If you don't remember to drive sensibly for 50 or so miles so the ECM can get it's bearings (reload some tables) and function properly.
Elmer
Old Mar 12, 2010 | 02:51 PM
Bill Dearborn's Avatar
Bill Dearborn
I have disconnected the battery several times in my Z when changing seats over to race seats. Each time I have done that nothing has happened. I didn't even know you were supposed to re-index the windows until I saw a posting on the forum. They always worked properly after I disconnected the battery.
Bill
To After Battery Replacement?
