Rotor Replacement
Old Mar 15, 2010 | 02:59 PM
waterluver55's Avatar
waterluver55
7th Gear
Default Rotor Replacement
I picked up some drilled and slotted rotors for my stock C6. I would like to know if there are any "gotchas" I should be aware of when I replace them this weekend. By that I mean the need for special tools, etc. I've got new DOT4 fluid.
I'm also wondering about the need for the hockey puck inserts for lifting the car. Are they necessary? I've done it before and didn't see the need. Ignorance can be very NON-blissful and I'd hate to mess things up.
Thanks!
Russell
Old Mar 15, 2010 | 03:16 PM
Richor's Avatar
Richor
CF Lifetime Member
Make sure to use the pucks otherwise you will damage the rocker panel ( side skirt ).
Here is a rotor installation thread. Search is your friend
http://forums.corvetteforum.com/c6-c...post1569963584
Old Mar 15, 2010 | 03:34 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
You don't HAVE to use the pucks. If you just take your time and place the jack head on the chassis lift points, instead of sticking it under and cranking away, you'll be fine without them. I've jacked mine plenty of times without them with no damage whatsoever.
If you are the type that feels they must have them, pick up a pack of hockey pucks from the local big sporting goods retailer and save about $40.
There's an entry about removing the rotors in the C6 FAQ with pics. if you're just replacing rotors, you'll save a little time by NOT removing the calipers from the brackets and just removing both as one piece.
Good luck! It's easy.
Old Mar 16, 2010 | 06:58 PM
waterluver55
7th Gear
Default Rotors and Pucks
Hey Filmjay, thanks for confirming what I thought was the case. I've lifted it a few times and was wondering what the hype was about lifting pucks: just be careful and take your time. I'll check the Rotor replacement C6 FAQ.
Old Mar 16, 2010 | 07:05 PM
Richor's Avatar
Richor
CF Lifetime Member
^ why not spend $3 on pucks and be safe
Old Mar 16, 2010 | 07:10 PM
waterluver55
7th Gear
Hey Richor, thank you for the excellent Rotor Replacement thread. I did a search before my post, but my search may have been too narrow. Many thanks, Russell.
Old Mar 17, 2010 | 07:55 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
The rears may fight you coming off. Try to not **** the parking brake shoe, it will jam the rotor. Sometimes a BFH is required. If you have the parking brake shoe spring come off, reassembly will probably require a lot of swearing. Search the C-5 forum for instructions- the C-5 and C-6 are the same.
Old Mar 18, 2010 | 12:08 PM
waterluver55
7th Gear
Thanks Dave, this is EXACTLY the type of info I'll need before doing the job this weekend. I'll now be aware of the E-brake shoes.
Russell
Old Mar 18, 2010 | 11:55 PM
peterpiper's Avatar
peterpiper
Default lock washer, Rust, e-brake, calipers
These are the only things holding the rotors on the hub:
lock washers, Rust, e-brake (rear only), calipers
The link from Richor pretty much summarizes it... keep in mind you don't need the washers... they are used in the factory to keep the rotors from falling off when the car is moved from station to station.
-pp
Old Mar 19, 2010 | 12:40 AM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
After trying to put mine back on for 2 1/2 hours, I said f*ck it and just took the whole thing off and took it to the shop to have them put it back on. There was A LOT of swearing and several thrown tools.
To Rotor Replacement
