Power Top Lockout defeat?
Old Mar 17, 2010 | 12:56 PM
CSixDude's Avatar
CSixDude
Default Power Top Lockout defeat?
Just curious, has anyone ever looked into defeating the lockout mechanism for the power top on the convertible that forces you to put the car in park to raise and lower the top?
I don't have the service manual or else I will check out the wiring diagram myself, but I suspect it is doable. I hate to reinvent the wheel though if someone has already gone down this road.
Old Mar 17, 2010 | 01:32 PM
Justasheet's Avatar
Justasheet
Why wouldn't you want to do this in park?
Old Mar 17, 2010 | 01:47 PM
TXC6Z51's Avatar
TXC6Z51
Not sure about an auto, but on a manual you can just raise up on the ebrake a little and drop the top while still rolling.
Old Mar 17, 2010 | 02:52 PM
CSixDude's Avatar
CSixDude
Interesting, I'll have to check that out, thanks.
My previous car had no lockout on the power top and it could be raised and lowered at any time. Obviously this requires you have a brain and don't try to put the top up or down at 70mph. When it helps is when you are at a stop light and only halfway through the cycle before the light turns green. With the lockout, you have to sit there and can't even put the car in gear till it is done. Without it, you could slowly motor through the intersection while letting the cycle finish to completion.
I'm thinking that there is probably an easy way to modify the wiring so that the system is fooled into thinking the car is in park, similar to the GPS fix.
Old Mar 17, 2010 | 04:16 PM
knkali's Avatar
knkali
same with auto trans and e brake thing.
Old Mar 17, 2010 | 05:21 PM
Justasheet's Avatar
Justasheet
I wonder what Law Enforcement would have to say about that. I guess you'd have to "have a brain" to attempt that.
Are you kidding me?
Jeff
Old Mar 17, 2010 | 05:32 PM
TXC6Z51's Avatar
TXC6Z51
Are you kidding me?
Jeff
What the heck are you talking about? Some people don't need the government to protect them from themselves. So yes if you have a brain you don't need some of these ridiculous safety features some cars have.
Old Mar 17, 2010 | 08:37 PM
Justasheet's Avatar
Justasheet
Okay, you convinced me, well maybe not. Something that prevents you from doing something stupid (in my opinion) is nonsense (in your opinion). I hope your right and I'm wrong and no one ever gets hurt doing this.
Old Mar 17, 2010 | 09:34 PM
CSixDude's Avatar
CSixDude
I just sold a 2002 WS6 Trans Am that had no lockout features on the convertible top, and it could be raised and lowered anytime while moving. I put mine up and down all the time at speeds under 10mph. It was actually nice to be able to jump in the car and pull out of the parking lot while lowering the top at the same time. It also was nice not to have to worry about putting the car in park at a stop light to lower or raise the top and if the light turned green I could still go, but I just had to go slowly until it was completed. The only real danger is getting too much wind in the top and having it turn into a sail when it is halfway through the process. As long as you use some common sense, it isn't a big deal.
From what others are saying, it sounds like all that may be needed is to tap into the emergency brake switch circuit and put a bypass switch on it that you can turn on and off.
Old Mar 17, 2010 | 10:05 PM
Justasheet's Avatar
Justasheet
Good luck my friend. You sound reasonable and intelligent. i just hope the guy behind you who is fascinated by your beautiful convertible isn't too distracted by it. Be safe.
Jeff
To Power Top Lockout defeat?
