Do your own headwork?
Old Mar 17, 2010 | 09:27 PM
Vettedebt79's Avatar
Vettedebt79
Default Do your own headwork?
I ordered a set of base casting l92s and from looking at all the pics of the ported/cnc l92s there is alot of casting flash and little imperfections from the factory. Would it hurt anything if i polished out the exhaust ports? I know the intake cant be mirror polished or anything cuz of the fuel building up on smooth walls hurting performance, but would it hurt anything if I got rid of the casting flash/buildup in the intake runners? Has there been anyone with the juevos to go as far as port thier own heads , if so please advise.
Old Mar 17, 2010 | 10:20 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
A while back, I pulled the head off my 1996 Corvette LT4 with the intention of porting them. After removing the valves, I concluded I really had no clue what I was doing so I sent them to a professional to clean them up and get them pocket ported. Its also a good idea to remove the valves while they are getting ported because all the metal fillings and get the valves ground and lapped to make sure they seal. I got them flowed to see how much of an improvement it made. I picked up 22 rwhp as a result. It cost about $500.
Old Mar 17, 2010 | 10:30 PM
c6 batmobile's Avatar
c6 batmobile
If you really dont know what youre doing sending them out is the way to go. It is important that they are done right or they wont perform.
Old Mar 17, 2010 | 11:06 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
I would recommend to either leave them how they are or have someone with experience and a flow bench do the porting.
Old Mar 18, 2010 | 04:53 PM
Mez's Avatar
Mez
You may think its OK just to do a touch up and remove the flashing, but you need to remove the valves. If you do that, you are bound to nick a valve seat when you do, so it will need them re-ground. A 5 angle valve job can pick up quite a bit of flow at low valve lift.
In my opinion, either don't touch them or send them to a well established professional to get them done right and flow tested.
To Do your own headwork?
