Alignment machines???
Old Mar 20, 2010 | 08:49 PM
User 81424's Avatar
User 81424
Default Alignment machines???
What kind of alignment machines do I need to look for at the shops?
Old Mar 20, 2010 | 09:06 PM
bob guzzy's Avatar
bob guzzy
I know Hunter is a good name in alignment machines but I would say any modern machine that has the 4 camera setup.
An alignment machine is only as good as the guy running it, you also need to find someone who is not in a big rush to do 10 more cars after yours.
Ask around where you live a good shop will have a good rep.
Old Mar 20, 2010 | 09:56 PM
User 81424's Avatar
User 81424
Old Mar 21, 2010 | 10:10 AM
rovers2000's Avatar
rovers2000
4 camera is important. I took my car to a place that had the lazer beams and they could not do my car because it is to low and the beam would not go under the car.
Old Mar 21, 2010 | 02:03 PM
Pylons's Avatar
Pylons
I'd be far more concerned about the technician than the equipment
Old Mar 22, 2010 | 05:36 AM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
I agree but a hunter with a good tech is the ticket. I good tech on a bad day and alignment machine can make a mistake - dont ask me how I know.
Old Mar 23, 2010 | 12:12 PM
ejbarre's Avatar
ejbarre
Hunter with an experienced technician.
Old Mar 24, 2010 | 07:20 PM
Kenny94945's Avatar
Kenny94945
Experienced tech (w/ Vettes) is the key.
Issues with align machines I've had include the Vette being to low to drive onto the ramp (including wood supplemental ramps), Laser beam being blocked by front air dam, the wheel/ rim mounted alignment mirrors not being big enough for Vette wheel rims, and these same wheel mounts marring the rim surface.
And then there is centering the steering wheel.
Old Mar 24, 2010 | 07:26 PM
User 81424's Avatar
User 81424
Old Mar 24, 2010 | 10:27 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I had my wife's alignment done by a bad tech on a good machine but he screwed it up big time. I could see it was wrong and after running fishing lines along both sides, I measured the right rear was toed in .5 inch. But the tech thought the wheel was toed out could not be aligned properly and maxed out the adjustment the wrong way. I got his supervisor over to look at it and instantly we both saw his mistake.
They fixed it on the 3rd try.
To Alignment machines???
