Coolant temp guage intermintent???
Old Mar 23, 2010 | 11:46 PM
dovervold's Avatar
dovervold
Default Coolant temp guage intermintent???
So my coolant temp guage works sometimes, and goes to zero sometimes. When it goes to zero I get the "engine hot, a/c not working" message in the dic. Then all of sudden the coolant guage will work again, no rhyme or reason.
I checked the connection at the coolant temp guage, and all wiring and connections seem good. Tried moving the wire harness as far as I could track it, and made no difference.
Is there any obvious things to check? Could the sender be bad, or more likely a wiring issue?
Old Mar 24, 2010 | 08:38 PM
HuskerBullet's Avatar
HuskerBullet
You've pretty much narrowed it down.
Old Mar 24, 2010 | 10:16 PM
oneblackvette's Avatar
oneblackvette
I will bet you have a 160* t stat right? The engine must warm up to a certain temp in a certain amount time or the PCM ignores the coolant temp sensor and you get that DIC warning. Some 160* stats have been known to cause this on cool days.
Old Mar 26, 2010 | 09:03 PM
juiced c6's Avatar
juiced c6
i had the same problem. I had air pockets in the cooling system.
Old Apr 14, 2010 | 12:18 AM
bowtiguy's Avatar
bowtiguy
I had this VERY SAME PROBLEM last weekend driving back from the road course. Turns out my T-stat was sticking!
Once I pulled the inners out of it and reinstalled to to make it home, I got this message all the way back.
When I fired it up in the driveway this AM to drive it to work I let it warm up to 180 degree water temp, no problems. When I drove home, I did not let it warm up completely. At 52 degree ambient temp it did not take long for the Ron Davis Radiator to dip temps below 150 degrees ===> engine hot A/C off message and coolant temp displayed = XXX.
Radiator is coming out on Froday to go back for warranty work ( slight leak) and a new T-stat will be installed. Already swapped in my spare Temp sender.
NOTE: I had to disconnect the battery for a few minutes to get it to re-set after installing the new sender.
Old Apr 14, 2010 | 07:24 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
I thought all the C-6 thermostats were not able to be disassembled. Do you have something different?
Old Apr 14, 2010 | 08:40 AM
bowtiguy's Avatar
bowtiguy
yep, a BIG flat head screw driver and a diaginal cutters.
I had to save the outer metal ring and the gasket that fits around it or it would have leaked.
Old Apr 14, 2010 | 10:08 AM
dovervold's Avatar
dovervold
Mine turned out to be the temp. sender. Replaced and works perfectly. Good luck on fixing your radiator. I heard Ron Davis builds a nice piece, but it has a leak???
To Coolant temp guage intermintent???
