Going Wide Body
Old Mar 29, 2010 | 11:20 AM
Le Mans Z06's Avatar
Le Mans Z06
How much of a difference is 18s vs 19s in the rear? I would personally like to keep 19s in the rear for the look, but if it makes a big difference it's not something I would want to do.
Old Mar 29, 2010 | 11:31 AM
vettemann62's Avatar
vettemann62
I switched & I hook up much better with the 18's than the 19's. "spinmonster" has a whole write up & comparison on this topic. Just do a search.
I didn't want to get rid of my 19's either but. I need the most traction possible & with a 35 profile tire the overall wheel size will be the same as you 19" with the 35 runflats.
Also yourC6/Z51 rotors & calipers wont look so puny with the 18's:-)
I dont miss my 19's at all!! My car has never looked better!!!
Old Mar 29, 2010 | 11:58 AM
Le Mans Z06
Originally Posted by sarecco
1) Unfortunately...."IT'S PAR FOR THE COURSE"when you're pushing 616 rwhp 594rwtq (soon to be 700hp) YOU NEED 345 WIDTH R COMPOUND TIRES & 12" wide rims or wider or all that power (some anyway) is being wasted, which negates the original purpose. 18" rims are a must, 19's hurt your cause!
You need AS MUCH Rubber on the road as possible and the only way to get 12" wide rims on a c6 is to flair or z06 the rear 1/4's. Mini tubing a c6 wont work because of the upper control arm restriction. So it is an absolute necessity. With this much power, I dead hook 2nd gear now in 65 degree weather with 3.42 gears and m/t 345-35-18. Some guys have squeezed 11" rims (without WB) on their c6's but the widest tires you can go comfortably is 305's or they begin to bulge.
2) mine handles great but the c6's handling is quadrupled when you dump the piece of crap sway bars for hp ones
3) yes it is very costly. It depends how you do it & how far you go, about 4 grand.... 4 rep wheels $905, 2 m/t 345-35-18 $650ish, rear widebooty kit about $1250, body shop paint and install about $1000 + incidentals.
4) OK, I did it for the looks too:-)
I hope this helped:-)
Was it an upgrade over the regular sway bars, or Z51 sway bars?
Old Mar 29, 2010 | 12:14 PM
vettemann62
I went with Hotchkis Sways. They are a HUGE upgrade over the stock c6, and are advertised as an upgrade for Z51 owners as well.
http://www.southerncarparts.com/corv...way-p-615.html
But there are many other alternatives. I have 3 stiffness settings on mine.
Old Mar 29, 2010 | 12:51 PM
EATURAW's Avatar
EATURAW
I have come to grips with the fact that my 19's will have to go soon.... With an 18" rim in the rear it will allow for more side wall, which in turn will result in FAR better traction.
With the power level I'm shooting for in the next couple months (600rwhp) I don't think I will have to go wide booty just yet. I will be ok with a 305 M/T in the rear under the stock fenders for now.
The wide booty looks great! I think I would rather dump most of that money into more performance. For me since I can hook up with 305 M/T's, under the stock rear quarters - the wide booty would be pretty much just cosmetic.
Decisions, decisions - all this crap is driving me nuts.
Old Mar 29, 2010 | 03:34 PM
vettemann62
I dont think you can find a 305/19 in a 35, just a 30, so they will be a little small looking in the wheel well. When i had mine, I lowered the car a little to compensate. They still looked small though but it's not the end of the world. Running lower tire pressures help hooken up as well.
Old Mar 29, 2010 | 04:27 PM
EATURAW's Avatar
EATURAW
I was referring to an 18 inch rim in the rear, with a 305 M/T.
I just can't bring myself to spend 4k on that modification, after new rims, tires, fender package and labor - it's right around 4k or so.
I bounce back and fourth everyday.... One day I say the power I have is enough for a street car/daily driver..I should do the wide booty, it will look bad *** with the wider wheel base and wider tires.
The next day I tell myself, my car isn't fast enough - Spend the money on more power, I don't need to spend 4k just to have the car look better.
What do you guys think?
Old Mar 29, 2010 | 05:02 PM
vettemann62
I would take a break from the forum before your head explodes....Been there so many times:-)
What's your current HP & TRQ to the wheels? Do you have any intentions to increase it in the next year or so?
Old Mar 29, 2010 | 05:45 PM
Le Mans Z06
He is looking to go from 490RWHP to ~600. 490 isn't confirmed on my end, but I'm pretty sure he is close to it.
Mike, my Dad's Vette runs at around 650RWHP and he runs a D/R set up on 18s (17s in front) with a 345 on it and has MAJOR traction issues. Keep in mind that's just a whopping 50 more RWHP, which at that power doesn't make a tremendous difference. He breaks loose and fish tails punching it at 100mph. That of course is with his boost at half.
Mike I know money into power seems like money well spent, but keep in mind that power is worthless without putting it to the ground. Find someone with a similar set up and PM them and ask their opinions. You won't be happy if you get more power and can't use it. Keep in mind with nitrous you can't control the power so when it comes in all at once you may be struggling to maintain control of the car, I know my Dad's has gone sideways a lot because the boost keeps coming in and it's very hard to control.
EDIT: Not only that, but you will spend the money on a stickier/wider tire now, then up your HP #s and then HAVE to go with a wide body at that point anyways, so if you do it first you will help your traction issues now and enjoy it, then when you get the power you won't have to deal with it.
Old Mar 29, 2010 | 06:06 PM
vettemann62
Upgrading Traction doesn't seem nearly as S-E-X-Y as adding more power, does it.
Hey, I didn't think i'd be spending so much on traction either! It's a lot of bucks when you start playing with F.I. But I'm "All-In" at this point, can't turn back now......
Old Mar 29, 2010 | 08:00 PM
XEUROTRASHOWNER's Avatar
XEUROTRASHOWNER
I have a set of grand sport wheels tires and sensors mounted and balanced with 550 miles on them- considering selling them. Let me know if your interested.
I can be reached @ 860-614-4840
Old Jun 23, 2010 | 06:45 PM
beynum vette's Avatar
beynum vette
I want to do a wide booty conversion I plan to put 20's on the back and 19's on the front what sizes tires do I need to get proper clerance i dont want the front tires to stick out the fenders and were do I find prepainted rear Z06 fenders and how much do they cost
Old Jun 23, 2010 | 08:59 PM
  #33
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Originally Posted by whiteboy
What am I missing ?? Why " Wide Body???? The look???? Isn't it pretty costly? Car any faster? Ride or handle any better? Or is it just a case of a ZR1 Wanna Be???
When you still haven't hooked up at 80+MPH with 500+ rwhp on stock width rears, you'll understand the need for wider rubber and hence the wide booty conversion.
Old Jun 24, 2010 | 01:21 AM
  #34
SpinMonster's Avatar
SpinMonster
Originally Posted by saplumr
Sounds like your choices are buying factory Z wheels (which you can find on here for good prices) or adding 1-1/2" rear spacers which can stress bearings.
The only stress is on the adapter itself which is the strongest metal on the car. Guys have run this without issue. The adapter plus the stock widened rim weighs less than after market garbage.
To answer the OP's question, a 1 3/4 to 2" will work for the adapter size and it has worked fine for many forum members. 2" puts the edge of the 19" rim close to the limit of the fender. A 345 tire on a 18x12.5 with a 1 3/4 is the limit for a widened 18 and the 19 widened to 12.5 to work with the 345/19 nitto can use the 2" because the 19 sits a little further inside the wheel well.
Traction is better with more sidewall so the MT ET street on the 18 is better.
The 19" with the NT05r looks great and lasts longer in that its a 00 compound with 6.3/32s to start life at. A 305/18 MT on a 18x11 is better than the 345/19 nitto for traction. A 275 on a 17 is better yet. You have to decide if bling is more important than performance. The C5R and C6R run 18's all around.
Old Aug 2, 2010 | 11:26 PM
  #35
Super-seed's Avatar
Super-seed
6th Gear
Default 1.5" spacers and wheels for wide body kit
I put the wide body kit on and bought the spacers to use until I ran the tires off. Worked great for 20,000 miles. I've just bought the wide wheels and have two 19x10 chrome Z06 style wheels and 1.5" spacers for sale.
Call or email if interested. David in IA, 319-480-0632, djn@n-connect.net
