Cam Install
Old Mar 31, 2010 | 09:47 AM
rskeller's Avatar
rskeller
Default Cam Install
Finally booked my Cam install on May 21 He reccommends getting the oil pump ported and shimmed has anyone else done this and do you recommend it.
Old Mar 31, 2010 | 10:26 AM
GregC6's Avatar
GregC6
i went with the melling HO pump, that is what my installer recommended
Old Mar 31, 2010 | 01:46 PM
CVS PERFORMANCE's Avatar
CVS PERFORMANCE
I went with the Melling HO pump as well.
The SLP HO pump is also another route you can go and it has some additional porting as well. It also has some clearencing done to accept the double roller timing sets with no issues.
Old Mar 31, 2010 | 01:57 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
I'm using a ported LS6 pump on my FI LS3. Works great! Solid pressures everywhere no matter the temperature.
They'll probably be upgrading the valve springs and pushrods as well, I suggest having the timing set upgraded while they're in there. Just a little more cheap insurance.
Just make sure they're not charging you a lot extra for installing/replacing/upgrading parts they're taking off anyway. Maybe it's just me, but that drives me NUTS!
Old Mar 31, 2010 | 03:58 PM
jflack's Avatar
jflack
What does a cam swap cost? Hi-po shop or dealer?
Old Mar 31, 2010 | 05:06 PM
GregC6's Avatar
GregC6
http://forums.corvetteforum.com/grea...m-special.html
Old Apr 1, 2010 | 10:15 AM
rskeller's Avatar
rskeller
Well I am paying 3700.00 for everything Cam,Install,Dyno,Pushrods,Valve Springs,Timing Chain and the Oil Pump work.
Old Apr 1, 2010 | 10:26 AM
GregC6's Avatar
GregC6
I did the same for 2k
Old Apr 1, 2010 | 10:30 AM
Isaiah48's Avatar
Isaiah48
I used a ported LS6 oil pump, works great and is only $100.
To Cam Install
