Raising C6 Front
Old Apr 6, 2010 | 08:22 PM
TightCornersRacing's Avatar
TightCornersRacing
Default Raising C6 Front
I just picked up an 08 C6, and need to raise the front. Im sure most likely been posted, but can someone how it can be raised on stock bolts. I have heard it can be raised about an in on stock bolts, I just have no idea how to complete.
Will need an alignment after as well im sure
Old Apr 6, 2010 | 08:28 PM
Richor's Avatar
Richor
CF Lifetime Member
here ya go
http://forums.corvetteforum.com/c6-t...l?forum_id=101
Its very easy to do. Should take 5 minutes per wheel max.
Old Apr 6, 2010 | 08:37 PM
timd38's Avatar
timd38
You may not be happy with the look.
Old Apr 6, 2010 | 08:39 PM
TightCornersRacing
assuming the link you sent was to lower, assuming counterclockwise lowers the car, clockwise raises the car. Is it called the trim height adjuster bolt?
Old Apr 6, 2010 | 08:50 PM
Richor's Avatar
Richor
CF Lifetime Member
I am not sure what it is called but you are correct regarding turning the bolt clockwise. Just do the opposite of what the link says and you will be good.
To Raising C6 Front
