ls3 maf on an ls2?
will the stock ls3 maf plug into an ls2? Just wondering b/c the ls3 maf is a better design for air flow.
also is the stock ls2 maf a 3 prong or 5 prong?
if your not over 500whp, dont even bother, its going to need a retune, and the stock ls3 airbox, or make your own maf housing
it uses a different connector, you can find it online, the stock connector comes apart and you can use the same pins to put in the new plug.
stick with the stock maf.
-Carl
