Seat Belt issue.
If they cant make right 60 bucks, hell even 40 bucks which is what the actual cost was + 20 bucks shipping, I would hate to buy anything substantial from them.
After a review of the Service Manual, it looks like the retractor mechanism MUST be oriented a certain way, and the belt MUST come vertically up out of the mechanism or it will lock. Here's one picture of it:
For some more info on part#s and names of parts see:
http://www.compnine.com/index.php?u=...14&grouptype=B
You can see how the retractor is oriented in the picture, but it's very misleading about how the other parts fit into the picture. The retractor actually mounts below that part identified as item# 13, and the belt comes vertically out of the top of the retractor and over that #13 bracket.
The Service Manual says that when checking the retractor for proper operation, that the belt should come out if the retractor is mounted as shown or a max of 15 degrees from that attitude, and the belt is pulled straight up out of the retractor. The belt should not pull out if the retractor is tilted 45 degrees or more from the mounting orientation shown.
Good luck with it!!
Bob
Anywho. There are 3 little gears that have to be oriented just the right way. Not sure exactly which way they go but I got them close. As I was sitting around thinking about what excuse they used, I thought "how many times do the seat belts ever get replaced after a collision?" umm never! Like VETTE PHASE said, the belts have no idea the bags deployed. The problem actually came when they removed the belts from the car. They allowed the belts to roll too far inside the spool, which locked the gear. Only way to reset it was disassemble.
Thanks to those who chimed in!! Regardless of the fact that I fixed the problem, it still sucks that they were unwilling to work with me and offered no help.
