Tool sizes for brake pad replacement
Caliper bolts (6 point ?? mm)
Brake Pad Pins (Torx ??)
Do I need some type piston compressor tool? Have never seen one for 6 pistons!
I am replacing 1 piece pads from Carbotech, so I need to remove the calipers.
Considering you've got the one piece pads and will need to remove the calipers, you'll need a 21 mm socket.
You don't need a clamp to compress the pistons - you can use a screwdriver to push them back while the calipers are still on to loosen them off the rotor.
After you get the calipers off you'll need to push the pistons down so the new/thicker pads will fit over the rotor (this will push fluid from the system up into the master cylinder, so take some fluid out and check to make sure it doesn't overflow). Although, you've got a 2010, so your OE pads can't be worn too much! If you've got a strong grip, just squeeze the pistons down with your fingers!
Below is how I pull the pads away from the rotor before removing the caliper:
And after I get the caliper off I push the pistons all the way down like below. I just push each piston down individually:
Good luck!!!
Bob
Wondering if it makes sense to bleed the brakes a bit to remove any fluid that might have been overheated as well as lowering the level in the reservoir to a safe level for compressing the pistons?
Also promotes getting fresh fluid in the system at every pad change.
Any comment on this?
PS> I splurged on a caliper compression tool I found at Mid America Motorworks. Seems like I would need to compress all 6 pistons at once. Won't a single side clamp push out the first side when the second is clamped?
I am out of town, so can't give you the correct torx bit size. Just go buy a full set for a 3/8 drive ratchet and you will be set for most jobs needing a torx.
