Penny method queston: Tread depth measurments
Apr 20, 2010 | 12:24 PM
The grove closest to me with the wheel mounted is at honest Abs hair. The other grooves are alot deeper going to Lincoln's mid-forehead.
I'm not sure if that means 2/32" are left or 4/32" Anyone know how to convert currency to rubber?
Apr 20, 2010 | 02:00 PM
Quote:
Originally Posted by
Insom
http://www.tirerack.com/tires/tirete....jsp?techid=51
Apr 20, 2010 | 02:09 PM
So I guess I go with the lowest which is in Abs hair.
Apr 20, 2010 | 04:11 PM
St. Jude Donor '15
"In honor of jpee"
yes, but if it's ok across the tread, you may not have to worry about it right away.
Apr 20, 2010 | 05:13 PM
Alignment or inflation issue too how severe I am not sure.
Apr 20, 2010 | 11:14 PM
just use a toothpick or something like that, measure the depth with it then use a ruler or tape measure to see how many 32's deep it went
Apr 21, 2010 | 12:10 AM
Tread measuring tools are cheap. I've got one.
OP, the wear bars on OEM non-Z51 tires are at 3/32" of tread. Many C6 owners here talk about replacing their tires at 2/32" of tread.
Apr 21, 2010 | 11:04 AM
2015 C7 of the Year Finalist
here is what I use Digital Tire Tread Depth Gauge (CEN3S401)
Apr 21, 2010 | 11:17 AM
St. Jude Donor '08-'09-'10
Where did you get that Gauge ?
Apr 21, 2010 | 06:29 PM
Mine is a simple manual gauge that I've had for 3 or 4 years, so I don't remember where I got mine, probably an auto parts store.
Apr 21, 2010 | 08:30 PM
