Lug nut torque.
Old Apr 25, 2010 | 07:55 PM
ASME's Avatar
ASME
Default Lug nut torque.
Can anyone give me the torque spec for the C6 factory polished wheels. Thanks
Old Apr 25, 2010 | 08:04 PM
ZPO's Avatar
ZPO
100 ft lbs.
Go to the FAQ section for great info:
http://forums.corvetteforum.com/c6-c...tions-new.html
Old Apr 25, 2010 | 08:08 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
and double check tq after a couple miles
Old Apr 25, 2010 | 08:21 PM
ASME's Avatar
ASME
Thanks.... I will.
Old Apr 25, 2010 | 09:51 PM
geewez's Avatar
geewez
I thought it was 85-87 Lbs ? Can't remember where I got that number from but that's what I'm using.
Old Apr 25, 2010 | 09:59 PM
Andy 53's Avatar
Andy 53
I checked my owner's manual a few days ago to get the lug nut torque spec. For a 2005 coupe it is 100 foot pounds. I have the polished aluminum wheels.
Andy
Old Apr 26, 2010 | 07:29 AM
GOLD72's Avatar
GOLD72
Too low!! GM specs for vette lug nuts has been 100 ft-lbs since at least the beginning of the C5 generation. My 99 Honda Accord is either 80 or 85 ft-lbs.
Old Apr 26, 2010 | 10:28 AM
Bill Dearborn's Avatar
Bill Dearborn
It has been at least 100 lbs since the beginning of the C4 era and may have been that high since the C3s started shipping with aluminum wheels. One thing I have found is it doesn't usually come loose once you get it that tight. After driving for a few days and rechecking the nuts do not turn any before the torque wrench clicks.
Bill
Old Apr 26, 2010 | 01:00 PM
GOLD72's Avatar
GOLD72
......... After driving for a few days and rechecking the nuts do not turn any before the torque wrench clicks.
Bill
My experience as well. I usually check the lugs a couple weeks later and more after the initial mounting and I have never found a lug nut less than the original torque value. I always use a 3-stage star pattern at 50, then 75 and finally at 100 ft-lbs with a Sears torque wrench that I store in my bedroom closet to keep it away from my humid garage.
Old Apr 26, 2010 | 11:39 PM
geewez's Avatar
geewez
I double checked-I'm running iForged wheels and the wheel manufacturer calls for 85lbs on their wheels.
Old Apr 27, 2010 | 09:10 PM
timd38's Avatar
timd38
Honda / Acura has the same size studs and nuts, but has a lower spec. I noticed that also when I put the winter tires on my Acura. I don't understand why they are different, but they are.
To Lug nut torque.
