LS2 to 3 Vararam
Old Apr 29, 2010 | 08:57 PM
Kevin Marshall's Avatar
Kevin Marshall
From: Love the Smokey Mountains and the Blue Ridge Parkway, Milton GA and Jupiter FL
Default LS2 to 3 Vararam
Hey Guys,
I just went LS2 to 3 and had a Vararam from my 06 on the shelf in the basement.
I was going to use the new Attack Blue on the 08 but thought I would revisit the Vararam to Maggie take off.
Called Vararam they said it would work, but upon closer inspection I am not so sure.
What do you do with the MAF sensor in factory Air box and the EVAP or PCV line in the accordian flex.
I do not see any provisions.
I just read for two hours and the only instructions I can find show LS2 pics. here and at Vararam.
Am I missing a piece that is necessary for the LS3?
Input appreciated
Thanks,
Kevin
Old May 1, 2010 | 08:07 PM
Kevin Marshall
ttt
Old May 2, 2010 | 05:30 PM
Kevin Marshall
Default LS2 to LS3
Guys,
With all of the Vararam fans, some one has an answer.
Give it up please, pretty please,
Thanks Kevin
Old May 2, 2010 | 06:18 PM
dennis50nj's Avatar
dennis50nj
Originally Posted by Kevin Marshall
Guys,
Thanks Kevin
you need a vararam maf housing like your ls2 maf housing, except the vararam one is blank so you can put your maf in it from the factory air box, hope this helps
Old May 2, 2010 | 06:19 PM
AirBusPilot's Avatar
AirBusPilot
I don't own a vararam, but the 08's have a different maf setup. I'm guessing you'll need that maf housing (vararam, IIRC, has that housing).
Old May 2, 2010 | 06:37 PM
Kevin Marshall
Dennis,
Yes, Thanks, This helps.
I believe LS2 used a MAF and LS3 a MAS, I need to put MAS in this blank piece from Vararam.
I might Use the Attack Blue, cleaner install, but I have Vararam on shelf, maybe I will donate it to the Forum for Saint Jude.
Or, I might just skip all that and order an E Force and skip all the little stuff.
Kevin
Old May 2, 2010 | 07:03 PM
dennis50nj's Avatar
dennis50nj
Dennis,
Kevin
a very worthy cause to donate to
To LS2 to 3 Vararam
