Adding Launch Control for 2009 C6
Old May 9, 2010 | 02:19 PM
PAmotorman's Avatar
PAmotorman
it is there to protect the drive line from warranty work not to enhance performance.
Old May 9, 2010 | 06:54 PM
GTPprix's Avatar
GTPprix
Originally Posted by SPC0127
Yep its up there but its for the Z06 not the coupe. Only one person has said it is possible on the coupe. I have been reading about the 2010 coupe and indeed Launch control is standard on that model. The brakes on the 2010 Coupe though, that's what I need confirmation of, are they the same system as the 2009??????? If that is the case then indeed Launch control should work unless someone knows differently, one poster here says they have done it, I'm simply looking for a second source to be sure its correct.
You probably arent going to find a second source since so far all the retrofits I've done. Not sure what more you are looking for, it works i've done it go try it LOL
Old May 9, 2010 | 07:08 PM
SPC0127's Avatar
SPC0127
Cruising
OK this I need to be sure of meaning I need to change the ECM and EBCM using 2010 coupe parts and reprogram and I am done correct?
Old May 10, 2010 | 11:49 AM
YWZ08's Avatar
YWZ08
How far back will the retrofit go? I have a 08 Z.
Old May 10, 2010 | 01:55 PM
SPC0127's Avatar
SPC0127
Cruising
It will not work in the 2008, only 2009
Old May 10, 2010 | 01:59 PM
SPC0127's Avatar
SPC0127
Cruising
This is simply not correct. Spinning the tires protects the drive train, the launch control enhances grip by reducing slippage.
Old May 13, 2010 | 02:07 AM
gomerjack's Avatar
gomerjack
Any vendor how really nails putting lc in pre-2010 Vettes will have a lot of biz...
