Need help choosing new heads!
Old May 3, 2010 | 08:54 PM
A-STYLE's Avatar
A-STYLE
7th Gear
Default Need help choosing new heads!
I have an 2005 ls3 based 418. Right now I have stock intake manifold, Callaway Honker Cold Air, and long tube headers, magicstick 4 cam.I will be adding a twin turbo setup in a couple months.(STS or APS) its still up in the air. What heads do you all think would best suit my setup.
Old May 4, 2010 | 01:34 AM
SpinMonster's Avatar
SpinMonster
A TT set-up will get you 800rwhp+ with stock 243s. Unless your goal is north of that just go with a wise cam choice or keep it cheap with box stock LS3 heads.
The best head is a Trick Flow 235 on that size bore but 3k is better spent on a fuel system and meth injection. Without those two mods you arent going even that high in power
Old May 5, 2010 | 02:53 AM
A-STYLE's Avatar
A-STYLE
7th Gear
Spin, thanks for the help. I know you used to port intake manifolds. What kind of intake do you think i need to run with a tt setup. I read somewhere that the new 102mm fast with the 102 nick williams will hold the boost no problem. I will be running at max 15psi. But more than likely closer to 8-10psi. Last Question. What fuel system do i need to be looking into and do i need to run an oil catch can?
To Need help choosing new heads!
