Problem after cam installation!
Old May 10, 2010 | 08:29 PM
warwolf's Avatar
warwolf
Default Problem after cam installation!
I have a 2006 LS2 manual 6. Just installed a 236/236 602/602 113ComCam last week. Having a few problems:
1. Hearing a loud, fast tapping sound coming from the engine. It comes and goes.
2. Whenever I push my clutch in to stop, RPMs drop down to almost 0 and then go back up to 800 and sits at idle.
Just wondering if anyone has ever experienced anything like this?
Old May 10, 2010 | 08:39 PM
johnodrake's Avatar
johnodrake
Moderator
#2 Happens to me on occasion, but not often. 230*/236* @ .050" .612"/.615" 115
Old May 10, 2010 | 09:34 PM
DONALD HALL's Avatar
DONALD HALL
A fast tapping sound might be something in the valve train, loose rocker, lifter not pumped up. Normal noise with larger cams.
The dropping idle is common with cams, however a good tuner can tune it out using something called minium idle air flow tables. Ask SpinMonster he knows. My tuner drilled a hole in the throttle plate this is NOT the recommened solution.
Hope this helps
Donald
Old May 10, 2010 | 09:37 PM
Motorhead-47's Avatar
Motorhead-47
Idle undershoot/overshoot can be corrected within the "Airflow Final Minimum" table....cam'd car must be tuned to run right and this is just one of the adjustments that must be made.
Old May 10, 2010 | 09:39 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
#1 could be a lifter preload issue, does it sound like a sewing machine?
#2 tuning issue, need to modify the park/neutral/coastdown airflow
Old May 10, 2010 | 09:44 PM
bob guzzy's Avatar
bob guzzy
The tapping could be a bad lifter, pumping out
Old May 10, 2010 | 10:06 PM
warwolf's Avatar
warwolf
yes it sounds just like a sewing machine.
Old May 10, 2010 | 10:53 PM
FastGhost's Avatar
FastGhost
Could be the wrong size push rods...I had that problem after installing a cam. After going back to a LS6 cam and the correct push rods the sawing machine sound went away. I agree that a good tuner will cure the the idle problem.
Old May 10, 2010 | 11:34 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just to clarify, Mr. Hall's PREVIOUS tuner drilled a hole in the t-body.
Old May 11, 2010 | 12:30 AM
chsmith112's Avatar
chsmith112
Mine sounds like a sewing machine too, but I believe that is just normal. I also have a ported FAST and LTs which don't help haha.
Old May 11, 2010 | 03:51 AM
DONALD HALL
Sorry EnglandGreen, yes it was a previous tuner that did the hole. The current tune has the car running very well, thank you.
Donald
Old May 11, 2010 | 06:03 AM
SpinMonster's Avatar
SpinMonster
Hope this helps
Donald
Don, shoot me your address and I will send you out a repaired TB blade. Send me your's back. Consider it contuned prior customer support. It carries a lifetime membership.
The idle is airflow table related and is easily fixed with a tweak.
The noise is from a lifter. What size pushrods do you have?
Old May 11, 2010 | 06:20 PM
warwolf's Avatar
warwolf
I ordered push rods, but they didn't get delivered in time so I left the stock push rods in.
Old May 11, 2010 | 08:37 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
I thought most big ls cams have a small base circle which might cause stock pushrods to be on the short side. Correct me if im wrong
Old May 11, 2010 | 09:08 PM
warwolf's Avatar
warwolf
what size push rods do i need?
Old May 11, 2010 | 09:35 PM
carlrx7's Avatar
carlrx7
you need to measure in order to get the right ones, probley shoot for the 7.425. but only a pushrod lenth checker will confirm.
goto a speed shop and grab one.
then pull up ls1tech and do a search on howto measure.
Old May 11, 2010 | 10:02 PM
Cajundude's Avatar
Cajundude
The tapping sounds like a lifter issue. If you are running stock heads with your cam, then 7.4 pushrods will work fine. As far as the rpms dropping up and down, that is more likely a tune issue.
To Problem after cam installation!
Old May 12, 2010 | 10:43 PM
warwolf's Avatar
warwolf
The tapping sound started on one side of the engine and then seemed to move to the other side of the engine now. I drove the car today and the tapping was very loud at first and then it went away completely. After driving a few more miles, the tapping came back again.
If this is a lifter issue, would the tapping come and go?
Or is it maybe trash in the engine?
Old May 19, 2010 | 11:12 PM
warwolf's Avatar
warwolf
how much would it cost to change the lifters in my car?
Old May 20, 2010 | 06:46 PM
Metallic311's Avatar
Metallic311
I was under the impression the sewing machine noise was normal for big cams. The valves are opening and closing violently in comparison to a stock cam, and the springs are heavier(or should be).
Can't remember if you listed headers, but those will allow the noise to resonate right to the interior.
I have a moderate cam in my 08 C6, it makes a light sewing machine noise--but it sounds in harmony with the engine, nothing seems out of place.
