Wasn't the gas cap
Old May 10, 2010 | 10:21 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Default Wasn't the gas cap
I had the "CHECK GAS CAP" message and the "Major leak in evap system" CEL come on. I thought it was another bad gas cap so I changed it. Everything was good for a couple of days, then both came on again.
I started checking under the hood while the engine was running and heard a slight hiss just behind the throttle body spacer. I took off the FRC and found this:
Is this the evaporator line? I assume it's part of the evap system since thats the code I threw. Would it be covered by the emissions warranty? TIA.
