09 2LT Airbox
Old May 11, 2010 | 03:30 PM
jborg's Avatar
jborg
Default 09 2LT Airbox
My 09 2LT has a huge OPEN oval air cleaner. There is no airbox at all. Did GM change the design this year? I cant see wasting money on anything but maybe a stock K&N replacement filter.
Old May 11, 2010 | 06:02 PM
haljensen's Avatar
haljensen
Pictures?
No air box means it's not stock.
K&N doesn't make just a replacement filter, you have to buy the filter/air box.
Old May 12, 2010 | 10:11 AM
jborg's Avatar
jborg
Default From the dealer
Thats how it came from the dealer. The filter is oval and blue. Can someone take a picture of what it should look like?
Old May 12, 2010 | 10:20 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
sounds like you have a replacement air filter assembly. why not take a pic of what you have and post it? just open a free photobucket account.
Old May 12, 2010 | 10:29 AM
jborg's Avatar
jborg
Default How Do I post a picture
Is it common for dealers to install options?
Old May 12, 2010 | 12:59 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
they will if they can make money on it. otherwise, if this was a used car, it was probably the prior owner. was it used?
Posting pics: go to c6 gen, top, FAQ section, about half way down, posting pics how to
Old May 12, 2010 | 02:23 PM
autoxnut's Avatar
autoxnut
I have replacement K&N air filters installed in my 2005. These are the rectangular filters that go into the stock airbox assembly. Purcahsed them at Funfest at MidAmerica Motor Works.
Originally Posted by haljensen
Pictures?
Old May 12, 2010 | 02:30 PM
08VRZ06's Avatar
08VRZ06
Cruise-In X Veteran
That is the way that it comes from the factory. The LS3 motor uses the same type of intake as the Z06. I believe the difference is the filter element. That's why on the aftermarket Intakes you will see them as LS3/Z06.
Mark
Old May 12, 2010 | 02:43 PM
jborg's Avatar
jborg
So an open blue oval air filter is factory?
Old May 12, 2010 | 04:55 PM
rmedina's Avatar
rmedina
Bro, just take a picture and post it.. Otherwise we are all just guessing on what you have.
Old May 12, 2010 | 05:03 PM
G00SEiv's Avatar
G00SEiv
this is what I pulled out of my '09 4LT
the below picture is stock:
Old May 12, 2010 | 06:45 PM
haljensen's Avatar
haljensen
His is an LS3, no K&N replacement filter for an LS3.
Old May 12, 2010 | 06:47 PM
haljensen's Avatar
haljensen
NO.
The picture in post #11 is a stock LS3 filter box. If you have something different it's not stock.
Old May 13, 2010 | 08:50 AM
jborg's Avatar
jborg
Default Thanks Goose
That is what I have! I was expecting a more enclosed airbox where with this one you can reach up either side and touch the filter. Seems open enough to me that replacing it wouldnt make that much of a difference.
Thanks for your help guys and I WILL learn how to post pictures for my next stupid question. Bear with me, this is my very first Corvette (and loving it!).
Old May 13, 2010 | 08:52 AM
jborg's Avatar
jborg
Default One more
What is the purpose of that smaller box on the passenger side?
Old May 13, 2010 | 09:43 AM
rmedina's Avatar
rmedina
It's just an air silencer. I replaced my air intake with the zo6 intake. It's the same thing minus the air silencer. I did this so I could could install a catch can. I can take a picture if you want. Have a good one..
Old May 13, 2010 | 10:24 AM
jborg's Avatar
jborg
Default A picture would be great
Any benefits? Better sound?
To 09 2LT Airbox
Old May 13, 2010 | 04:33 PM
rmedina's Avatar
rmedina
It has a little more "roar" on WOT..
Old May 15, 2010 | 10:13 AM
G00SEiv's Avatar
G00SEiv
Here is what I replaced my intake with --
the extra little box on the right is for sound deadening purposes.. and for eating little bits of horsepower
Old May 15, 2010 | 10:27 AM
theofel's Avatar
theofel
St. Jude Donor '10-'13
The air silencer really doesn't do anything. Just cut it off and block the hole. Now it is the same as a ZO6 air intake. There is a relacement filter for this unit..but..it is not made by K&N. I believe the name of the product is "Attack Blue Air Filter". I hope this helps you.
