Physical (visual) differences between "base" and "Z51" brake brackets.
Old May 11, 2010 | 06:28 PM
SPANKY LS1's Avatar
SPANKY LS1
Default Physical (visual) differences between "base" and "Z51" brake brackets.
What are the visual differences between Z51 and base brake brackets, in other words, if I am holding a set of each, how can I identify which is which? Pics would be helpful, if you have a pic of either, please post them.
Thanks, Shawn
Old May 11, 2010 | 06:58 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
z51 's are taller
Old May 11, 2010 | 09:05 PM
oneblackvette's Avatar
oneblackvette
the z51 are longer from the mounting bolts to the pad perches.
To Physical (visual) differences between "base" and "Z51" brake brackets.
