tock 2007 with 100 shot???
Old May 13, 2010 | 05:04 PM
theSOUTHtexasBULLY's Avatar
theSOUTHtexasBULLY
Default stock 2007 with 100 shot?
my vette is a stock 07 6 speed...im gonna install a cai and a 100 hp wet shot...what should i run at the track??my friend has a 06 mustang gt with every bolt on,cams,and a 125 shot and he runs a 12.2 at 112 mph..i dont want to lose to a mustang and i sure in hell dont want to lose to a buddy of mine lol...what do yall think????
Last edited by theSOUTHtexasBULLY; May 14, 2010 at 03:13 PM. Reason: misspelled word
Old May 13, 2010 | 07:23 PM
SpinMonster's Avatar
SpinMonster
The C6 stock runs near 12.2
Old May 13, 2010 | 11:55 PM
theSOUTHtexasBULLY
Default thanks
thanks bro...im starting to feel more and more confident..ive had the pleasure of running into some mustang guys here in houston with all kinds of mods and ive destroyed em..i think i got this with a 100 shot,drag radials,and a cai.....we'll see???
Old May 14, 2010 | 11:12 AM
FloydSummerOf68's Avatar
FloydSummerOf68
You should be able to run mid 11s pretty easily with that setup on Drag Radials.
Old May 14, 2010 | 11:54 AM
bps999's Avatar
bps999
your et could vary alot depending on conditions, traction and your launch. What are you running stock without the nitrous?
Old May 14, 2010 | 12:00 PM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
vararam and headers would put you close to 11s
Old May 14, 2010 | 03:08 PM
theSOUTHtexasBULLY
my car is bone stock...im having a problem speed shifting from 2nd to 3rd gear so i'll probably need a aftermarket short throw shifter,drag radials,cai,and a wet shot??? i havent taken my car to the track yet but im going as soon as the weather clears up here in Houston..i'll definately do a test run bone stock....either way,im not losing to this guy....
Old May 14, 2010 | 03:21 PM
LS1LT1's Avatar
LS1LT1
For the record, all 2007 Corvettes are 6 speeds. It's just that some of them are 6 speed manuals and some are 6 speed automatics.
I assume that your's is a manual.
The key words there might be 'drag radials', should probably be the first area that you address.
You might not really need the nitrous but it certainly can provide a nice insurance policy. If you do go with nitrous you might want to consider using a smaller shot (50? 75?) when going up a against a mere low 12 second car because that might be all you'll need and you might find a little more consistency (and traction) with it plus the bottles will last a little longer between fillings.
Last thing ya want to have happen is a bottle going low (or empty) when ya need it most.
Old May 14, 2010 | 05:26 PM
bps999's Avatar
bps999
I'll give you my opinion for what it's worth...
There's no reason to speed shift it or change the shifter. You need alot of experience launching the car before you will get even close to it's max potential. It's not wise to plan mods before you have any strip experience.
Finally, forget this guy. go to the strip for your own reasons and take your time, at this rate your going to end up with a broken car and losing the race anyway.
Old May 14, 2010 | 05:35 PM
C7&7's Avatar
C7&7
You'll be fine...It's all in the traction though...If you guys went from a 30-40 roll you would walk him big time...
Old May 14, 2010 | 06:44 PM
Whisky's Avatar
Whisky
Get some experience and hone your technique!
Old May 14, 2010 | 08:13 PM
theSOUTHtexasBULLY
Default reply
thanks for all yalls help and input..once this weather clears up in houston i'll take my car to the track and get some practice..i figure a cai,exhaust,DR's,75 shot,and a little practice on the track and i should smoke him...thanks guys
Old May 15, 2010 | 10:34 PM
STiRob's Avatar
STiRob
When your friend ran that 12.2 @112 was he using the nitrous? A full bolt on (cams, heads , headers) 2005+ Mustang is more than capable of running those numbers on motor alone with a good driver and using drag radials.
Old May 16, 2010 | 02:27 PM
theSOUTHtexasBULLY
Default stock 07
yes he was using nitrous.he ran with a 125 shot.he doesnt have aftermarket heads,as far as internals he has cams...his mph does not impress me..
Old May 16, 2010 | 06:25 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
With boltons, a 75 shot, and tires it would not even be close. Just practice launching and you will not even need the bottle.
Old May 16, 2010 | 06:52 PM
FloydSummerOf68
Heads/Cams aren't boltons.
To tock 2007 with 100 shot???
