Best trans fluid for MN6?
Old May 15, 2010 | 10:25 AM
Cybernetic Medic's Avatar
Cybernetic Medic
Default Best trans fluid for MN6?
I have read some of the posts on changing the fluid in the MN6 trans to improve shifting. Is there any consensus on which is the best... Royal Purple, Amsoil, Redline or just the stock fluid changed more often? Is there any downside to changing it, i.e. voiding the warranty etc.?
I know it's a common problem and a trait of these transmissions but I'm disappointed the way my recently acquired 07 shifts.
Old May 15, 2010 | 12:24 PM
drivinfast's Avatar
drivinfast
Depending on the use there is an issue with the bushings holding the shifter bracket down.
Also there are at least 5 aftermarket shifters
Disappointed how? do you miss 3rd or 5th? mushy?
Old May 15, 2010 | 06:55 PM
REVAK's Avatar
REVAK
I have had good results with royal purple sycromax for the trans oil. I also recommend the mgw shifter and frequent clutch fluid changes. [search the ranger method, it works ]
Old May 15, 2010 | 08:19 PM
Robls6's Avatar
Robls6
RPM filled my brand new Level V trans with O'Reilly parts store regular Dextron ATF and said that is all I should use. That's all I needed to hear.
Old May 15, 2010 | 10:07 PM
Hoonose's Avatar
Hoonose
I put Redline into my early '05 this year without any notable effect or improvement.
Old May 16, 2010 | 07:30 AM
Cybernetic Medic
The same problems that others have. Notchy shift to 2nd, reluctance to go into 1st or reverse when cold, and a general stiff feeling to shifts.
By comparison, my old 91 Srealth with 185k on it shifts like butter. I know from that car that the trans fluid can make a big difference.
Old May 16, 2010 | 07:35 AM
timd38's Avatar
timd38
I use Redline with an MGW shifter and am happy.
Old May 16, 2010 | 07:39 AM
slvr06z51's Avatar
slvr06z51
RP SyncroMax made a world of difference. Then added a MGW shifter a week after that. Finally got the desired shift feel that I thought a Vette should have from the day it rolled off the assembly line.
-Nick
Old May 16, 2010 | 07:53 AM
Cybernetic Medic
Pretty hard to argue with that... If there was an advantage to using one of the other ATF's out there you would think they would endorse it.
Old May 16, 2010 | 01:37 PM
c6_rob's Avatar
c6_rob
Using royal purple here, happy camper
Old May 16, 2010 | 10:02 PM
oneblackvette's Avatar
oneblackvette
-Nick
Old May 17, 2010 | 12:40 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
im running the old amsoil atf in mine ,, its ok. i think they should send me a case of the new stuff and ill send by this case of old crap! lol
Old May 17, 2010 | 07:30 AM
GOLD72's Avatar
GOLD72
That was also my experience with Redline D4-ATF that I put into my 01Z06 at ~20k. Then again I haven't seen SOTP improvement using AMSOIL ATF in my 06Z06 either.
Old May 17, 2010 | 10:55 AM
NormWild's Avatar
NormWild
Most are better than the factory fluid, and most people will have not tried multiple fluids to give you any reliable comparison. It will be more of whether people are fans of a particular brand. I figured you can't go wrong with Amsoil, so that is what I used.
Old May 18, 2010 | 01:52 AM
C4RACER's Avatar
C4RACER
Friend of mine runs a performance vette and camaro shop in NC. The recommendation he got from an actual Tremec engineer was to run only Mobil1 ATF, which could very well also be the factory fill.
Old May 18, 2010 | 10:50 AM
C2C6Z06's Avatar
C2C6Z06
St. Jude Donor '08-'09-'11-'12
Royal Purple made a big difference on the notchy 1-2 shift issue for me....SOLD!
Old May 18, 2010 | 12:07 PM
lsbrodsky's Avatar
lsbrodsky
Been lots of threads on this over the years. I went with Royal Purple and love it. Already had an MGW shifter. Also an 07.
Larry
To Best trans fluid for MN6?
Old May 19, 2010 | 12:39 PM
JRHAWK9's Avatar
JRHAWK9
RP Syncromax here also, although in colder temps we get here in early Spring and Fall I still do have issues with the 1-2 shift until the car gets warmed up.
Old May 19, 2010 | 06:05 PM
Bandit1's Avatar
Bandit1
AMSOIL. Talk to "Subdriver". He'll hook you up.
JoesC5's Avatar
JoesC5
I drained the factory fill from my 09 Z06 and replaced with the RP Syncromax and drove it. It was way worse then the factory fill. Drained it, and replaced with Mobil1 ATF and it appeared to be about the same as the factory fill, maybe a tad better. I've put around 5,000 miles on the car since the fluid change and it's a little better shifting 1-2 & 2-3 but I'm still not happy having to granny shift to keep the nibbles/grinds in check. I get my 56 down off the lift every once and awhile and am surprised how well it shifts(1970 Muncie 4 speed/Hurst shifter). It's stiffer shifting then the Z06's transmission but goes into gear with no syncro nibbles/grinds.
