LS2 Cam Decision...Split Duration or Straight Up?
Old May 18, 2010 | 11:13 PM
FloydSummerOf68's Avatar
FloydSummerOf68
Default LS2 Cam Decision...Split Duration or Straight Up?
What tends to be the better way to go on cam-only LS2's?
Straight up or Traditional Split?
Also, how much overlap are people running on A6's?
Old May 19, 2010 | 12:01 AM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
what are your mods?
Old May 19, 2010 | 12:27 AM
SpinMonster's Avatar
SpinMonster
With stock stall A6's I run a 224/224 115+0 and its -6 overlap and 700rpm idle with great manners.
Old May 19, 2010 | 07:27 AM
FloydSummerOf68
Originally Posted by carlrx7
what are your mods?
Just assume a full bolton car with stock heads.
Old May 19, 2010 | 09:55 AM
epic's Avatar
epic
Uh oh....
Keeping stock stall? I'm doing a 2800 stall with 3.42 gears, with a G5X2 cam from LG. If you wait a bit, I can tell you how this combo is. LG says you can run the G5X1 with a stock stall I'm pretty certain.
Old May 19, 2010 | 10:38 AM
FloydSummerOf68
Originally Posted by epic
Uh oh....
Dealing with you on 1 forum is enough
I'll probably do a converter, just will be waiting a bit to see how it drives, if I think it's necessary, etc...
I just can't stand not having a cammed car. I miss the sound too much. Longtubes and borla doesn't have enough guts for me
Old May 19, 2010 | 10:42 AM
epic's Avatar
epic
Same boat as me buddy.
I'd say do it right the first time and put a baby stall in it like I am. It'll still allow you to accelerate aggressively enough out of turns, while still allowing you to put a bigger cam (ie: g5x2) for more power. Two people on the board somewhere have this setup and had rave reviews. Also spoke with Anthony at LG and he agreed.
To LS2 Cam Decision...Split Duration or Straight Up?
