Ever since I got a new set of Potenza RE-11s installed and a racier alignment, between 45 and 55 miles/hour, the message, "Traction System Active" is displayed. I can reproduce this at will, and in different gears, in a straight line, barely on the throttle. Has anyone experienced this before? Anyone have any ideas what could be causing this?
Sounds like you may have a mismatch on tire sizes. The computer is reading your front tires as moving slower than the back tires and trying to compensate.
Duh. How did I not think of this. Doing the math, I went from tire diameters (f/r, inches) 21.86/22.93 to 22.33/22.60. Does anyone know if I can use my HP Tuners to reprogram the correct sizes in the cars computer?
HPTuners will only allow you to do a speedo correction. You will need to get a taller rear tire.
Screw that, I'll just make sure to turn TC off every time I get in the car. I'm not giving my RE11s up and they don't make anything taller for the rear.
Yeah, I forgot to double the value for sidewall height before adding it to the diameter. So much for quickie tire size spreadsheet. The point still remains that I increased the size of the front tires relative to the rears and that is causing my problems.
