Cost 2 replace tire pressure sensor?
And I certainly don't know why a sensor should be bad on a C6. Even the oldest 2005 C6 isn't anywhere close to the time period where sensor batteries should be running low on power. The sensors have a design life of 10 years, but I guess yours could be somehow be getting weak.
I'd be more likely to think the sensor had been damaged somehow. Have you done anything recently that would expose the sensor to being damaged - like mounting new tires???
New sensors are available from several forum vendors (Gene Culley, Bob's House of Wheels, etc.) for around $60 shipped.
Your profile shows you have a 2006, so you need a sensor with GM Part# 25758220 (or a compatible aftermarket one). Do an internet search for "25758220" and you'll find a bunch of sellers - including used ones on fleabay for around $30.
You'll have to go to a tire shop to have them break the bead to get the old sensor out and the new one in. That shouldn't cost more than $15. If they keep the tire from slipping on the wheel, no balancing should be required - just reseat the bead and set your normal tire pressure and stick it back on the car.
Then you'll need to have them perform a sensor relearn procedure to program the new sensor ID# into the TPMS computer in the car and you'll be done.
Bob
Bob
And before the question comes up.....the tire shop owner is a friend. He did not sell the TPMS to me. I provided the TPMS to him for installation.
Andy
My 2005 is now owned by my brother-in-law. It was an early build '05 (Aug 2004), and the sensors are still working great.
The C5 sensors were advertised to be good for 7 years or 100,000 miles, but many owner's sensors are still working after more than 10 years.
BTW, the C6 sensors are all exactly the same for the 2005-2009 cars. Schrader didn't do anything different in the design or manufacturing process in 2008.
However, the 2010 and newer C6 uses a different sensor.
But.....that "new" sensor has been used on several other GM vehicles for several years now, so they're not really new at all, and they have the same design life as all other current Schrader sensors - 10 years.
Bob
Bob
Andy
Once the new sensors are installed in the tires (get the tires re-balanced at the same time for nothing more than piece of mind if he will due such for free), the programming the new sensors into the car are a snap once you have your hands on a rest tool.
Notice the order of which you need to program each wheel back into the RCDLR once you have got the car into TPMS mode, starting with the drivers front tire first, then working around the car clockwise each tire to you end up with the drivers rear tire last for the double horn honk telling you that all 4 tire TPMS have been programmed into the car!!!!
To add, before you replace the sensor, try to reprogam then back into the car. Hence the RCDLR can glitch once in a while to forget a sensor or two, and if the sensors are still good (battery still has power in them), they should program back into the car.
Myself, I have a Cub pro-101 that I can take a quick reading of the TPMS to see if the batteries in them are still good before even putting the car into re-learn mode to program then back in.
Attachment 48333004
And before you ask, yes there is a way to change out the batteries in the TPMS for about $10 total. The glitch is you need to have them out of the tires to dig the old battier out and solder new one in to start with. Hence $8 dollars for the batteries, and $2 for just new rubber grommets for the stems before you put the TPMS back in the rims.
https://www.corvetteforum.com/forums...placement.html
