LS2 Rod Bolt torquing
Old Jun 5, 2010 | 03:58 PM
Res1cue's Avatar
Res1cue
Default LS2 Rod Bolt torquing
Can someone with a shop manual provide the torque values and procedure for re-torquing 2005 LS2 connecting rod bolts. They can be re-torqued right? Pistons need to be removed for inspection
Old Jun 5, 2010 | 05:09 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
search the ls1tech forum. big discussion about that over there
Old Jun 5, 2010 | 05:46 PM
jsilvz's Avatar
jsilvz
15 lb/ft first pass and 75 degrees second pass according to shop manual. nothing said about being one time bolts like the balancer.
Old Jun 5, 2010 | 05:51 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
You can get a Torque Angle Meter like the one below at Autozone or a similar store for ~ $10.
To LS2 Rod Bolt torquing
